Swapping from EFI to a Carb in a Thirdgen
Old Jan 10, 2001 | 08:25 PM
LmpBzkt's Avatar
I was considering doing this swap and I was wondering if anyone knew if the fuel pump relay is controlled by the computer or not. I have been told that it is not but I'm not sure. If so how would i rewire it to get it to cut on when I crank up the car? Thank you.
Old Jan 11, 2001 | 04:20 AM
Super Phil's Avatar
Hey,
I got your e-mail. Like I said, hopefully Jester will respond because I am not sure on this. Also, I'll ask my brother-in-law. He would probably know for sure.
Phil
Old Jan 11, 2001 | 05:57 AM
SeanSullivan's Avatar
If you have a 3 wire oil pressure sender then the fuel pump is on and runing any time there is oil pressure. If you pull the computer and harness you'll have to hard wire the fuel pump to be on with the key, and off when the key is off.
Old Jan 11, 2001 | 07:03 AM
Jester's Avatar
The fuel pump is relay controled, not ECM. If you yank the harness too, you will have to do something to reconnect the relay.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jan 11, 2001 | 03:01 PM
LmpBzkt's Avatar
Could I run the hotwire to my ignition coil to the relay somehow?
Old Jan 11, 2001 | 05:20 PM
LmpBzkt's Avatar
So if I unhook the wiring from the ecm and remove it from my car I will have to reconnect the relay?
Old Jan 11, 2001 | 08:34 PM
I left the harness in place, just removed the ECM and the fuel pump worked fine.
Old Jan 11, 2001 | 08:55 PM
LmpBzkt's Avatar
So if I leave the wiring in and remove the ECM the fuel pump will work like it should?
Old Jan 12, 2001 | 01:52 AM
Super Phil's Avatar
Yes. You can pull out the computer, but leave the wiring harness in place. All your gauges and fuel pump should still work fine.
Phil
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
beachrodder
Aug 25, 2015 08:05 AM
