What controls the opening of the vacuum secondaries on carbs?
Old Mar 30, 2002 | 12:09 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I know that vacuum does (duh), but more specifically, how is it adjusted? In other words, how does the carb 'know' to open the secondaries once it reaches a certain vacuum, and what part of the carb is responsible for doing this (I need to know what part to change in order to get the secondaries to open sooner/later)? I apologize, but I haven't gotten my book on Holley carbs yet.
Old Mar 30, 2002 | 01:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Using a lighter or heavier secondary spring will make the secondaries open sooner or later.
Old Mar 31, 2002 | 12:22 PM
Jester's Avatar
Holleys have a ported vacuum source that goes to the vacuum bell on the secondaries, as opposed to a manifold vacuum source. That means that the more air flows past it, the more "pull" it has. Ported vacuum is always 0 at idle, but increases as rpm does. This pull is resisted by a spring which can be changed out, which lets you tailor how soon the secondaries open reletive to the needs of the motor.
Old Apr 1, 2002 | 12:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'll agree except for the part about it being in the secondaries. The port is in the primary venturi area (see http://www.holley.com/HiOctn/TechSer...fo/TI-223.html ).
Old Apr 1, 2002 | 01:05 PM
82camaro's Avatar
Car: 82 camaro SC
What 57 said. It's air flow through the "primaries" used to open the secondaries that is regulated by a spring.
Old Apr 1, 2002 | 02:48 PM
five7kid's Avatar
I should have said "secondaries only", since the port goes to both the primary and secondary venturis.
Read the Holley info, and the secondary port "adds to that in the primary verturi to give a stronger signal to the diaphragm".
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
