convertible top liner
Old Jan 26, 2004 | 03:56 PM
87 convertible's Avatar
Car: 87 20th anv lt sport coupe convertible
Transmission: 700 r4
Ok ,i know this is going to sound stupid,but my question is, i see alot of talk about liners when people refer to convertible tops.i have had my vert for 9 years now,and yes i need to replace the top,the liner does it cover the whole under side of the top ? mine just has two wide canvas strips on each side.Is this the liner everyone talks about ,or is my car missing it? believe it or not i have never actually looked at another vert while the top was up.Thanks in advance for your help.
Old Jan 26, 2004 | 05:52 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I believe they started putting the liner in these convertibles in either 1989 or 1990. I have a '90 and my car came with one. It covers the entire underside of the connvertible top .
Old Jan 27, 2004 | 04:58 AM
that would explain it since mine is an 87,thanks for the info.
Old Jan 27, 2004 | 11:23 AM
Guest
Guest
Posts: n/a
89's dont have it.
Old Jan 27, 2004 | 11:30 AM
89 Drop Top's Avatar
Car: 89 RS Convertible (Original owner)
Axle/Gears: 3.73 With Zexel Torsen Ltd. slip
They started putting the liners in in '90. Needless to say, when I saw that, I was a little upset being that my '89 didn't come with one! . From what I understand, the top frame structure was changed a little in '90 also, maybe to accomidate the extra material??
Old Jan 27, 2004 | 12:02 PM
so this is probably where the different measurements come from when ordering a replacement top,i know you have two areas you have to measure,so you get the right top.thanks ,you guys have been very informative.
Old Jan 28, 2004 | 07:26 AM
Graboid's Avatar
i wanna see a pic of a convertible top with the headliner
Old Jan 30, 2004 | 02:51 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Can you install a standard headliner from a with one to one that didn't come with one is the good question. I would really like to add one to my car and make the inside look nicer with the top up.
Old Jan 30, 2004 | 03:51 PM
thats a good question,be nice to know if anyone has done it ,or if it can be done.i am thinking the inside of the tops the bows and stuff might be a little different on the cars that came with the liners.
Old Feb 2, 2004 | 07:11 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
There isn't really that much to the headliner itself. There are a couple of U shaped plastic pieces that you would probably have to get from a junked vert, but with most of the parts you could probably just take measurements and make one on your own.
Old Feb 4, 2004 | 09:47 PM
1986sc's Avatar
Car: 92 Z28 92 RS Vert
Engine: 350 TPI 305 TBI
Transmission: 700R4 Auto (2x)
my 92 RS vert came with factory headliner. will get pics when my garage gets a little warmer. next couple of days. later
Ryan
1992 Trans Am
May 10, 2023 07:19 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
qz6lwp
Aug 20, 2015 08:10 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
