Convertible ground effect VS. Hard top GFX??
Old Mar 17, 2004 | 11:50 AM
Jtito21's Avatar
Car: 89 Camaro RS Vert
I have a Convertible Camaro and the passenger side ground effect is cracked. My questions is this: will a ground effect from a regular hardtop/T-top camaro fit my convertilbe camaro? Are there any differences in these gfx peices? If so what are they? Any pics/diagrams would be helpfull guys. I am getting the feeling that any part for our cars are gunna be hard to find. I cant find a convertible gfx peice so now I am hoping I can just use a regual one and just get it painted. Unless any one sees this has a convertible gfx peice to sell I would be happy to take it.
Old Mar 17, 2004 | 05:03 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
they should be the same. Call thirdgenresource (aka f-body motorsports) and they'd be able to tell you absolutely. See the link up top.
Old Mar 17, 2004 | 05:27 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
You'll have to modify the coupe piece to fit the convertible. One longitudinal cut, removing the back couple of inches should do. Ya see, the convertible frame support runs from the front to the rear wheel and is approximately a 4" x 4" x (length) piece of steel. It gets in the way of the rocker. My dimensions are not precise.
Old Mar 19, 2004 | 11:14 PM
Ovrclck350's Avatar
Roy @ thirdgenresource told me they were different. In all honesty, I haven't actually LOOKED at the difference yet. I do however have his stock white rocker GFX from the white LS1 vert sitting in my shed. If I get around to it, I'll check the difference.
Old Mar 20, 2004 | 01:30 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Convertible GFX are modified from hardtop pieces.
Lon
Old Apr 17, 2004 | 10:54 PM
RicksRedNomad's Avatar
Car: Several
Engine: Several
Transmission: several
My 87 Sport Coupe vert has no GFX on it now, Can i modify some that i have from a 1986 Iroc-Z to work on the Coupe??
I know that i will have to make some kind of flange to mount on the ASC support that run's the length of car, Any other tip's to help out with the install would be great.......
Old Apr 17, 2004 | 10:57 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ASC put a cut in the bottom of them when they put the vert bracing on.
get another GFX from a coupe, and with tin snips/a knife/sissors/cutoff wheel/whatever, just cut as needed.
Old Apr 18, 2004 | 10:27 AM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
i replaced the left front fender on my 'vert and i bought a new fender from gm , the body shop dude told me he had to cut the bottom of the fender to accommodate for bracing , so i would speculate the gfx was also modified. these cars all started as coupes so why not just modify a coupe piece. as we all know , finding parts for these cars are a nightmare anyway so i would think that it would be cheaper and more convienient to go the modifying route.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
LittleFranks
Aug 20, 2015 03:55 PM
92firebirdchris
Aug 14, 2015 11:56 AM
