Trouble
Old Apr 24, 2004 | 09:39 AM
Graboid's Avatar
Trouble
Ok, folks. It looks like i have lost my keys (all of 'em). The car is unlocked in my garage, so i can get inside the car to change the lock. The problem is the trunk, how do i get in the damn trunk? Any ideas?
Old Apr 24, 2004 | 09:55 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Graboid,
If you can get in the passenger compartment of the car couldn't you flip down the rear seat, pop the toneau, and then reach back to the trunck latch and open it? I know, there is some plastic stuff between you and the latch but If memory serves me right there are two plastic screws inside the compartment that holds that plastic in place. I can't right off remember if there are any fastners on top. I believe that with a screwdriver and a flashlight you should be able to pop the catch and get the trunk open without even having to remove an interior panel...
Sounds like more fun than a guy should be allowed to have!
Good Luck! Let me know how you come out!
Speedy
Old Apr 26, 2004 | 06:11 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
There are two small screws on the top side.
Old Apr 27, 2004 | 04:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Either crawl in and peel the bottom of the plastic panel forward and reach up to pull the cable that goes from the tumbler to the latch, or you may be able to pull the hatch light out of the panel and turn it with a screwdriver, the 2nd i know works on the newer 91-92 motor, and i use the first on the older ones.
Old Apr 27, 2004 | 05:54 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Well iin the US over here if you take your VIN and proof of ownership to a dealer you can get new keys cut.
If your willing to spend some $$ maybe call a locksmith and have him pick it.
Old May 6, 2004 | 09:48 PM
Car: '90 RS Vert
Engine: 305 TBI
Hey Graboid,
Have you gotten your trunk open yet?
Old May 7, 2004 | 12:20 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Once you've crawled into the trunk you can pop out the rear hatch light lens. You'll have access to the 10mm screw that holds on the manual trunk release. Once you've removed it you'll see a square hole. Move the tab inside that square hole to the right and it will pop the trunk.
Lon
Old May 11, 2004 | 12:46 PM
Graboid's Avatar
i have opened the trunk, it was rather easy, because i found the keys some days ago........
Old May 11, 2004 | 03:49 PM
Car: '90 RS Vert
Engine: 305 TBI
Keys!
Dang! That takes all the adventure out of it!
Glad you found them.
Speedy
Old May 14, 2004 | 05:11 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
well where did you forget em at...lol.
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
