3-point stb?
Subscribe
Dec 19, 2004 | 07:27 PM
Who has one and are they worth it? Do they get rid of the *** awfull cowl shake these verts have? I have been slowely going through my car and have now replaced all front and rear suspension peices with new (spohn lca's/panhard rod, kyb gr-2/gas-adjust, moog 5665/5662 springs, lca bushings, ball joints, strut mounts). I've also added alston sfc's and a wonderbar but the cowl shake is still unbearable. I was planning on getting a vortec stealthram for the new engine this winter but will not if the three-pointer actually rids the car of cowl shake.
Reply 0
Dec 20, 2004 | 10:26 PM
Kenny Brown, Edelbrock....... Nobody has one on their vert?
Reply 0
Dec 21, 2004 | 12:36 PM
Well, I guess I'll let you guys know. I just ordered the Kenny Brown 3-pointer.
Reply 0
Dec 21, 2004 | 03:20 PM
I've Got One!
Hi!
Sorry I haven't replied before now I've been pretty busy...
I have the Edelbrok STB installed on my car. Id does make a diffrence in the handling of the car and it eleminates a lot of the creaking and groaning as you go over uneven terrain.
The part that made the most diffrence in the stiffness IMHO was the Wonderbar that bolts underneath.
To answer your question is it worth it?
Definitly!
Speedy
Reply 0
Dec 21, 2004 | 04:23 PM
I have the KB one and i like it ..
Edit the only prob I have with it is i can't pull the dizzy without taking the brace off... no biggie really if I'm pullin the diz there is usually more coming out anyway
Reply 0
Dec 21, 2004 | 04:58 PM
Do they get rid of the cowl shake?
Reply 0
Dec 22, 2004 | 11:51 AM
I never really noticed any Cowl shake before or after...
I have heard that they do reduce cowl shake but I cannot relate personal experience...
Speedy
Reply 0
Dec 22, 2004 | 01:13 PM
Quote:
Let us know how you like it... of all the STB's on the market, I think I like the KB best, at least from a styling and 'perceived functionality' standpoint. KB makes good stuff, I'm looking to buy one of these soon.
Reply 0
Dec 22, 2004 | 01:42 PM
[QUOTE]Originally posted by gmgod
Do they get rid of the cowl shake? [/QUOTE
The STB (2 or 3 point) is a handling mod. To eliminate the cowl shake, install a good set of welded in SFC's designed for a convertible. Just my opinion on IROC coupe. And I have the Steering box support (AKA wonder bar) ,STB (2-point) and welded in SFC's. And by far the best is the SFC's.
Reply 0
Dec 22, 2004 | 03:58 PM
I already welded in a set of alstons and put on a TDS wonderbar. I think a 3-point stb would stabalize the cowl with the strut towers....... I guess I'll find out soon enough, will report back.
Reply 0
Dec 23, 2004 | 08:11 AM
A three point brace will help with cowl shake. It helped mine alot. I don't think a two point would help at all with the shake problem. It would have no connection with the firewall and that's where the problem is.
Reply 0
Dec 23, 2004 | 06:00 PM
The Wonderbar did marvels with my car. That three point brace looks like a winner too.
And that LS1... ahhhh. Yummy.
Reply 0
Dec 24, 2004 | 05:46 PM
I think I came across a Wonderbar on eBay and was not aware of it's use. Is there pics of all addable braces and locations via this board? I'd like to compare what I have and what I could or may need as improvements. I'm thinking of detailing some work on my car as reference with my Handycam.
Problem is I have one jack at present... My dad suggests I get some cinderblocks instead of $$ on jackstands hehe. That's still a challenge. Love to get underneath shots as reference but can't think of a way outside of the mechanic's lift ;:~)
BILL
Pic is of the throttle body moved during my thermistat repair. Still got a hot running engine but the coolant is leaking via bad
gasket(s) Need the clip for the throttle cable, if anyone can oblige?
Reply 0
Dec 30, 2004 | 09:21 AM
Well, I got the stb in and went to install it. I've got a problem, The part of the brace that bolts to the strut towers hits the strut mounts before the part that bolts to the firewall hits the firewall. I'm about a 1/4 inch away. I think the new strut mounts come farther forward on the strut towers than the factory ones. I'm going to fix that this weekend with a grinder.
Reply 0
Dec 30, 2004 | 05:57 PM
gmgod,
Hi!
When I first got my STB I took it out of the box and laid it in place under the hood and looked at it real hard for about 20minutes. Something just did not look right. I did not have time to fool with it right then so I just boxed it up and put it in a corner of my storage room where it stayed for about three months.
Later, I got it out and tried to put it in place and to visualize the installation and still it did not seem right.
I finally put the tower brackets on the ends of the brace and tightened them down so that you had to actually put some effort into changing their position. I then put the STB in under the hood and slid it around until I finally found the position that they were designed to occupy. Once I found that position I took a marker and marked where all the holes would need to be drilled. I then drilled and installed with no problems.
All it took was a couple minutes with the device basically assembled moving it around until I found the right position where all three attachment points hit. You might try that before you resort to the ole grinder...
Good Luck
Speedy
Reply 0
Dec 31, 2004 | 08:09 AM
I appreciate the tip, but the kenny brown stb is all one peice . I've got the strut mounts scribed and will take them off to clearance them..... Its only gonna take about 3/8th's to make it right.
Reply 0
Jan 3, 2005 | 06:59 PM
The BMR piece looks good to me. I'm not overly crazy about drilling holes around the struts or grinding on 'em.
Reply 0
Jan 15, 2005 | 12:53 PM
cinderblocks for support
if you use cinderblocks, just be sure you set them as they are to be used and not flat solid sides up, as they can easily collapse that way......set them properly and a piece of 2x12 on top has worked for me, but jackstands are much better......
Reply 0
Subscribe
