Vert replacement carpeting...
Old May 1, 2006 | 09:42 AM
92RagTopFla's Avatar
Can anyone PLEASE tell me where I can buy replacement carpeting for my "92 Ro vert....all I can find is carpeting for the hatchbacks. Also is the floor pan in the front part of a vert the same as in the hatchback....I was thinking of just trimming the carpet myself under the back seat...I would appreciate any feed back on my carpeting dilemma.
Old May 1, 2006 | 10:32 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
The carpeting is the same front and rear for coupes and convertibles
so that should make your search a bit easier
-jason
Old May 1, 2006 | 10:55 AM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
I am interested in this too. Which carpet is the best? Is it possible to get it in one piece? I don't like the seam on the two piece.
Old May 1, 2006 | 11:17 AM
'92 vert carpet replacement
Thanks a lot, I had as 91 coupe and the depression on the drivers side on my vert looks exactly the same.
Old May 1, 2006 | 01:12 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
You will have to make a few cuts in the carpet to get to fit in a convertible, but its nothing you will see once its in place and glued down.
Old May 1, 2006 | 04:30 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
the only difference in the hard tops and the verts is the top, the tonneua cover and the trunk lid!!!
Old May 1, 2006 | 05:06 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
as said before, the carpet pieces are the same for coupes and convertibles.
do not get carpet from Year One, their supplier sucks really bad. they have no warranty on the carpet after it is installed in your car i bought new carpet from them last year and it already started fading from grey to a teal color took a while to get a replacement,hopefully the new stuff doesn't go bad so fast, or i'll be REALLY pissed.
Old May 1, 2006 | 08:17 PM
92vert's Avatar
Car: 1992 Firebird Convertible
Engine: 305 TBI V8
Just installed mine from Classic Industries. Perfect color match and great fit.
Old May 4, 2006 | 10:53 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
anyone try this carpet from 1AAuto on ebay? says it is direct replacement.
Old May 5, 2006 | 03:53 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
No carpet is a "direct" replacement. They all need slight modifications and cuts to fit. Nothing major. You just need to cut the holes for the seatbelt bolts, maybe the manual shifter, some extra bracing in the trunk and that's pretty much it.
The carpets usually come premolded but with no holes. That's up to the installer.
Hope this helps.
Lou
Old May 5, 2006 | 03:59 PM
slohand's Avatar
Car: 91 z-28 conv.
understand about that, just wondered if anyone had tried them or if they bought new carpet from someone they are happy with.
from comments Year One won't be my choice.
Old May 5, 2006 | 04:05 PM
BigBadLou's Avatar
Engine: TPI
Forgot to mention that I bought carpet from Hawks but they screwed up the order and made me pay the restocking fee (a lot of money) on the wrong carpet they sent me. I think it's clear why I haven't bought anything from them since. But their carpet fits fine and the color match was good.
Lou
Old May 5, 2006 | 08:14 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
PM 'Jim85IROC'. He sells the ACS (better) carpet, good price and fast shipping. Finally got mine in a few weeks ago and it looks great.
Kevin D.
Old May 8, 2006 | 09:13 AM
92vert's Avatar
Engine: 305 TBI V8
The carpet from Classic Industries did require some minor cutting as described above, seatbelts and trim. It was pre-moldes with insulation already attached. Color and fit are excellent.
Old May 12, 2006 | 09:18 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Give it a few months with the top down and it won't be such a good color match anymore.
The ACC carpet is notorious for fading.
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
Gumby
Members Camaros
Aug 21, 2015 12:50 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
