Chop my top
Old Nov 10, 2006 | 12:56 AM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
Chop my top
Does anybody know of any company that does the camaro conversion from coupe to vert because im dieng for a vert and my car is in incredible shape.
Old Nov 10, 2006 | 05:06 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
if its in incredible shape keep it how it is and dont start cuttin it up!!there was a thred about this awhile back but useing the seach might help abit just go buy a vert
Old Nov 15, 2006 | 09:04 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The investment you make into converting your car into a Convertible would not offset getting a convertible, it would be much cheeper. You cnaget a convertible Camaro or Firebird from $2500 to $8000, it would cost you at least $8000 today to get your car converted, especially if you do not have T-tops. Then it would not be worth as much as a ASC convertible to start with.
John
Old Nov 15, 2006 | 04:57 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
look at my post on the subject.. Ive been there done that.
Bought a totalled vert for all the parts. If you have the tallent to do body work and weld you can do it NO PROBLEM. Its not rocket science. If you can make a straight line you can do it. Have someone do the welding if you can't.
https://www.thirdgen.org/forums/conv...ard-top-t.html
https://www.thirdgen.org/forums/conv...onversion.html
iM SURE YOU CAN FIND MORE DO A SEARCH
https://www.thirdgen.org/forums/conv...my-almost.html
Old Nov 15, 2006 | 09:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm in for a cheap vert if anyone knows where ones at. I have a donor hardtop for parts.
Old Nov 16, 2006 | 07:50 AM
okfoz's Avatar
To do the conversion, basically you should find a salvaged car, a sawsall.
I was not saying it was impossible, but if the car is rusted then I would not thing it would be wise.
From what I can tell you need the Subframe connectors, some aircraft rivets, Cherry locks might work. THe top and the back seat interior trim pieces... the seatbelts, front and read depending on your year. the tonneau lid, top and trunk.
Thinking about the differences,
1) you would first rtemove all stuff from donor car.
2) Install subframe connectors,
3) remove rear interior trim.
4) remove speakers, and wires for dome lights
5) Cut off top
6) inspect the original convertible for changes, IE in the wheel well area.
7) Modify car to match donor car
8) Weld brackets in for the seatbelts, and braces from side to side.
9) Paint the interior metal pieces black like original verts
10) Install all hardware, top, seals etc onto car.
I would suspect that you will spend $1000 for odds & ends to do the conversion, not including any paint, once you get a donor car.
John
Old Nov 17, 2006 | 11:28 PM
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
look at this http://sfbay.craigslist.org/sby/car/236208923.html
Old Nov 20, 2006 | 08:01 AM
okfoz's Avatar
Originally Posted by 0uTcast13
Its gone... deleted by author.
John
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
