My vert is a little off!
Old Mar 12, 2007 | 03:24 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi,
I looked over the tech specs and production numbers for firebirds that year and found no information that matches what I have in the vert.
First of all I have the WS6 package (bigger swaybars tell me that), but I also have an aluminum Driveshaft (checked with magnet). Also, my rear end is drum but it just doesn't seem to be a 2.73 peg leg. First of all it seems to be a posi. Every time I do a burnout I get both tires to spin evenly. I cruise at around 2000RPM's at 70-75MPH in OD. It close to that! Thats how my 3.23 rear end behaved that I had in my previous car.
I am just not sure how this is possible?!?!
You guys got any ideas.
I'll be ordering pontiac service info on my car, as well as getting the dealer to get my cars production sheet (I still have to talk to the person that suggested it, so I am not sure what the sheet is called)
Oh, also.
I am the second owner, the previous owner was an older guy in his late 60's who did not know much about cars and always had it serviced at the dealer. So, I assume that these things came with the car from the factory.
Last edited by xlwhellraiser; Mar 12, 2007 at 03:26 PM. Reason: Automerged Doublepost
Old Mar 12, 2007 | 08:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You dont need to call the dealership, although that printout is easier and nicer.
You can just run the RPO codes from the center consel on this site or the internet.
As for the driveshaft, I have read that if someone brought it in and complained of vibrations, that was a commen install/swap.
Gears, swaybars, posi are a commen change, even if it was an old man that owned it.
Old Mar 12, 2007 | 09:12 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Btripp on www.sethirdgen.org has two WS6 verts. He posts on here, but under a different screen name. They came with weird options like 3.23 posi drum rears and such. Dunno why though
Enjoy the car!
-jason
Old Mar 12, 2007 | 11:59 PM
Oh, only IF I had the RPO codes in the console. None of the third gens I owned had RPO codes.
I'll get one from the dealer, they should have one for a 92!
Old Mar 20, 2007 | 10:52 AM
Guest
Guest
Posts: n/a
Rear discs were N/A on a vert in 92.
I dont know about the posi and 3.23, might be part of the package tied to the engine.
Old Apr 15, 2007 | 10:01 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Re: My vert is a little off!
Good luck with that, I tried that 4-5 years ago for my 92 and the dealerships around here could not help me. They told me they had already purged the 92 and older rpo codes from the system.
Old Apr 15, 2007 | 06:08 PM
Found that out the hard way.
I can still get info for the car from pontiac historical services.
Old May 8, 2007 | 04:35 PM
82suped-up-coupe's Avatar
I know that mine and the few other 91-92 vert TA's out my way all have 3.08 posi drum rearends
and my rpo's show that this is correct for my 91 TA
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
okfoz
Oct 13, 2015 02:19 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
tcarlos13
Sep 2, 2015 07:29 PM
