Our first vert!
Old Apr 24, 2008 | 06:54 AM
Danni Slater's Avatar
Car: 92 rs Camero Vert
Transmission: 4 Speed Auto
Axle/Gears: Stock for 92 RS
Our first vert!
I'm new to convertibles so can some one tell me the steps to putting the top down? I've got a 1992 rs. It's a 25th year Anrv all Black. also I found a plastic piece in the trunk with a slight curve and it's marked on each end front and back. does it have anything to do with the top?
Last edited by Danni Slater; Apr 24, 2008 at 10:14 PM. Reason: Add pict. Still trying to add pict!
Old Apr 24, 2008 | 01:33 PM
cool z's Avatar
Car: 91 Camaro vert
Re: Our first vert!
can we see pics of the car and take pics of the peice you found and we might be able to help you
Old Apr 24, 2008 | 02:14 PM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
Re: Our first vert!
to get the top off if you're sitting in the back seat behind the passenger there's a little handle you pull back, this opens up the tonneau cover then up front by the visors there's to handles you pull back then you should be able to put the top down :thumbsup
Old Apr 24, 2008 | 02:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Our first vert!
z28 started it for you.
1.In the back drivers side, slide that lever forward. Flip the rear of the top up.
2.Now, next to that lever is a switch. Hit it, flip that cover lid up.
3.Flip the rear of the top back down.
4.Go to the top of the windshield inside. Under the sunvisors, rotate the two handles 180 deg.
5. grab the top, pull it up and back at the same time and it should colapse into the storage area, unless some of the mechanisms are damage.
6. Flip the cover lid back down.
done
Tips!
Make sure the passanger door is open, or the window is down before taking the top up, or down!
The cover lid and trunk lid can not be open at the same time
pray you never have a flat. Getting that spare out is an SOB
In case you do have a flat. Make sure you have the "can o air", or an air pump that plugs into the cig socket.
Welcome to the boards, and welcome to verts!
Old Apr 24, 2008 | 06:26 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Our first vert!
Scroll down to my 6th post in this topic . . .
https://www.thirdgen.org/forums/conv...upplement.html
There you will find my very detailed description, plus helpful tips how to avoid any damage or future problems. Plus there are some pics of my ride, in the link I made, describing the process.
Welcome to the vert family!
Old Apr 24, 2008 | 06:53 PM
Re: Our first vert!
CoolZ I got a few picts of the car I will try to post them and will break out the digi camera and take a few picts of the plastic thing I'm talking about.. I did put the top down and go for a drive today It was a blast!!!!
Old Apr 24, 2008 | 10:40 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Re: Our first vert!
WELCOME and please post some pics, I never tire of looking at verts.
Old Apr 25, 2008 | 11:04 AM
Re: Our first vert!
How do you post picts? I got one posted on my avatar from there I'm a total noob on posting picts.
Old Apr 25, 2008 | 11:08 AM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: Our first vert!
when you're going to post something click on go advanced then manage attachments and from there click on browse and point it to your picture
Old Apr 25, 2008 | 01:23 PM
cool z's Avatar
Car: 91 Camaro vert
Re: Our first vert!
if its the plastic peace im thinking of keep it and take care of it as much as posible... it might be the ultra rare plastic peice for the top
Old Apr 25, 2008 | 07:30 PM
Re: Our first vert!
Well I can post a picture of me put it tells me a picture of the car is to big. Boy ain't technolage great!? I'm at a loss#*+#!!!
Attached Thumbnails Our first vert!-100-0102.jpg   Our first vert!-100-0101.jpg
Last edited by Danni Slater; Apr 25, 2008 at 08:17 PM. Reason: Woo Hoo bygoly I think I got it!!
Old Apr 25, 2008 | 07:41 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Re: Our first vert!
I guess you need to edit and resize your pic.
Old Apr 25, 2008 | 08:08 PM
Re: Our first vert!
Thank You!!!! I'm still pretty new at this stuff, but I'm a fairly quick learner that just needs a little proding for time to time.. The pict in # 11 and on my profile is when wife and I found it and bought it for a play toy. Heres a pict with the lid down.
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
okfoz
Oct 13, 2015 02:19 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
tcarlos13
Sep 2, 2015 07:29 PM
