removing rocker GFX
Old May 4, 2008 | 11:57 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
removing rocker GFX
I have removed hardtop GFX before so I know how they come off. Well on this vert I see they have welded a plate for the setbelt where there is normally a hole to access the GFX bolts.
I have come to terms I will have to drill/tourch a hole for this. Can someone tell me how far up, and how far back/forward I will have to cut to have access to this bolt?
Old May 4, 2008 | 01:30 PM
TeK-91z28's Avatar
Car: 91 z28 convert
Transmission: 5speed
Re: removing rocker GFX
i never cut my car to re/re the GFX before amd after paint.
Old May 4, 2008 | 08:18 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Ive heard you can actually access that bolt threw the vent in the door jam (not sure the exact name of the vent). I'd try that before cutting anything.
Old May 4, 2008 | 08:39 PM
Dale's Avatar
Engine: 350 S-TPI
to late. I drilled a hole.
Never thought of the door vent, ops.
Anyone need pics of the subframes or anything, ask this week, lol.
Old May 5, 2008 | 08:55 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I tried the vent, didnt work with my arms. lol I drilled a 5/8ths hole through the side and got to them that way.
Old May 6, 2008 | 04:22 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Is that access panel for the rear bolt covered by this seat belt plate? Is that what you are referring to? Just wondering, cuz that would have been the best way to do it.
Old May 6, 2008 | 08:36 PM
Dale's Avatar
Engine: 350 S-TPI
correct, thats what I was talking about is where the seatbelt bracing is welded in.
Old May 24, 2008 | 11:30 AM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Guys, I am having the same issue.
So is drilling the hole the best way to do this?
Please..help.
Thanks.
Old May 24, 2008 | 06:25 PM
Dale's Avatar
Engine: 350 S-TPI
I never pulled the door vents. But that hole looks WAY high and I dont think my arms are that long or small.
Old May 30, 2008 | 11:36 AM
S10Wildside's Avatar
Same issue here. This past weekend I drilled a hole for access. Turned out just fine.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
