What SFC's to get
Old Jun 6, 2008 | 08:56 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
What SFC's to get
I am tired of all the squeaking and body flex and cracked dashes so I'm finally gonna get some Sub-frame connectors. I see some on Hawk's that say "for covertibles". Do I need to get SFCs made specifically for a vert?
Either way what are teh best ones to get? I don't want to spend a fortune but I want to get this right. i'm leaning strongly toward the weld in kind.
Old Jun 6, 2008 | 10:30 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: What SFC's to get
Some won't work with verts. Get the Alston's from Lon at Top Down Solutions. I think they are $189. That is going to be the next mod for my vert.
Old Jun 7, 2008 | 08:13 AM
Engine: 350 TBI
Thanks. I'll check them out.
Old Jun 7, 2008 | 08:25 AM
Stephen's Avatar
Car: 87 GTA
The only advantage to bolt-on ones is....You can bolt them in place, drive to a welder, then have them welded in place. But I see no reason you couldn't simply drill the bolt holes in the weld-on ones, then TEMPRORARILY bolt them in place to get to a welder, if you can't weld yourself.
Old Jun 7, 2008 | 07:38 PM
Oldred's Avatar
Car: 1991 Z28 Convertible
Alston's all the way. That and the Wonderbar was the best money I ever spent.
Old Jun 7, 2008 | 08:33 PM
Engine: 350 TBI
Is the wonderbar a strut tower brace? Did it help with the squaking and creaking or just the handling?
Old Jun 7, 2008 | 09:35 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
i dont have sub frames but i do have a wonderbar, car still drives like a wet noodle if the road isnt flat. the subframes is where its at. when i drove i put my finger between the top and the windshield area and feel all the flex in the car. I'm going to need subframe connectors as my next purchase for my 92
the wonderbar is similar to the strut tower brace, but it goes under the front end. bolts to where your swaybar bolts.
sturt tower brace is also a good investment. get the car as solid as possible
Old Jun 8, 2008 | 03:39 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You can weld in the Alston SFC's instead of or in addition to bolting them. That's why I offer the SFC install kit (bolts & nuts) as an option in case you just want to just weld them in.
I know it's a tough choice, which SFC to get? Powder-coated gloss black or gloss red. If you can't decide, get them un-coated (bare steel) and you can have them powder-coated or rattle-can painted in any color you desire.
Lon Salgren
Old Jun 8, 2008 | 05:52 PM
Engine: 350 TBI
Thanks Lon. I'll check into how much it will cost me around here to get them welded and hopefully get them soon.
I don't want to mess with bolting them in and then having them wleded. I'll just take them to the automotive welding shop.
Old Jun 8, 2008 | 07:27 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Lons connectors are the way to go. I have them on my convertible and they really do help. Also, from Lon I got the wonderbar. Very good too.
Old Jun 8, 2008 | 09:37 PM
Engine: 350 TBI
Anything in particular make Lon's SFC's better than the vert-specific ones that Hawk's has?
Old Jun 8, 2008 | 09:42 PM
Stephen's Avatar
Car: 87 GTA
Why does everybody keeps calling them "Lon's" when they are Alstons. He sells the Alston brand SFCs, not his own design....
Alston has the best design IMO. I'm just trying to come up with the $400 for the Alston SFCs & Lon's Deluxe Door Hinge reapair kit. Maybe next month or August.
Old Jun 9, 2008 | 11:32 AM
davey_boy_smith's Avatar
Car: 1991 Camaro Z28 Convertible
Transmission: 5 speed
Axle/Gears: 3.08 posi
i went with the spohn SFC's because they were specificially made to fit with the reinforced rocker panels in verts. they tucked in nicely without comprimising any ground clearance (cleaner). also, they were able to stitch weld them 1" every 4" or so. Plus they have an extra Y or T branch that welds onto the main frame member that adds more rigidity. see pics below (not my car). IMO, it doesn't get any better than this.
Old Jun 9, 2008 | 04:47 PM
Stephen's Avatar
Car: 87 GTA
Those look home-made to me. They don't tie into the front subframe except for the 'T' piece. While they might be better than nothing, I'd hardly call them worth the effort of putting those on.
I see room for improvement for those.
Old Jun 12, 2008 | 01:58 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I think the spohns make the car more rigid. I've got the Alstons and they helped some, but the car still has noticable cowl shake. It drives me freakin nuts. I've got a Kenny Brown 3 point STB I need to install, but have little faith that it will cure the shake. I'm thinking the only way to get it right is to remove the rocker GFX and fenders, and stitch weld all the ASC bracing along the rockers and firewall...... then maybe add the spohns.
Old Jun 12, 2008 | 06:18 PM
Engine: 350 TBI
Can somebody give me an idea what they paid to get the their SFC's welded in? am I looking at $300 or $50?
Old Jun 12, 2008 | 06:59 PM
Firebat's Avatar
People on here used to say to get Alstons and Spohns. Thats if you get really crazy.
Old Jun 12, 2008 | 08:47 PM
Engine: 350 TBI
So you can install both on the same car? I'm not trying to make it stiff enough to drag race, just enough to stop squeaking.
Which one should I get if I only get one? a second set would be way down the road.
Sounds like the majority of folks so far like the alstons.
I'd dtill like to get an idea what some folks have paid to get them welded in.
Old Jun 12, 2008 | 09:35 PM
Engine: 350 TBI
Old Jun 12, 2008 | 11:47 PM
Firebat's Avatar
I've just heard you can install both, never seen pics of it done yet though. I just bought my friend a couple good dinners at a sit-down restaurant to have him weld in my stuff. An exhaust shop or a body shop might be able to weld them in, someone that has a lift and a welder. I'm guessing $75-100.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Aftermarket Product Review
Apr 28, 2001 05:02 AM
