This is probably not kosher but . .
Old Jun 26, 2008 | 01:17 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
. . . there are so many post on the engine board that they quickly fall on down the list.
So - I ask my fellow vert lovers if they can give me a hand with an issue that is DRIVING ME CRAZY.
https://www.thirdgen.org/forums/tech...ml#post3803127
Old Jun 26, 2008 | 02:10 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: This is probably not kosher but . .
What is the timing set at with the EST wire disconnected? What do you have the plug gap set at???
it could be the rear binding up. I had that issue when there was too much play in the gears..... just a thought.
-jason
Old Jun 26, 2008 | 05:09 PM
91 Ragtop's Avatar
Car: 1991 Trans Am Convertible
Transmission: 5-Speed
Have you checked the injectors? I just had the injectors replaced on mine and it runs 100X better. I did have the bucking issue at low rpm's. The car would idle rough when warm. It finally died when my brother was driving it. It would start but didn't have any power.
Of course I paid more to have the injectors replaced than the motor is probably worth...
Old Jun 26, 2008 | 10:19 PM
davey_boy_smith's Avatar
Car: 1991 Camaro Z28 Convertible
Transmission: 5 speed
Axle/Gears: 3.08 posi
i've had the same problem for years now. i've been chasing a ghost as it keeps disappearing whenever i look to investigate it and re-appears whenever you don't want it to (ie when ppl are in the car). so i feel your frustration dude.
i have most of the same parts replaced including my injectors (before the problem occurred). so i am not sure if they're the problem. now having said that, i recently put lucas injector cleaner in it and its ran w/o incident since. not sure if that had any effect or not. only time will tell.
also note that i had a similar problem (plus other symptoms) with a 3.1 corsica many years ago. it ended up being a bad computer. i never would have guessed. shrug.
Old Jun 27, 2008 | 12:36 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I'd be looking at the injecors too. Also while I'm at it, I might replace the O2 sensor. If it's never been replaced, it might be worthwhile.
midnightfirews6
Dec 3, 2013 06:31 AM
duntovlives
Mar 5, 2013 09:03 PM
Jason E
Mar 29, 2012 12:59 PM
