Thinkin of selling my vert
Car: 91 RS Vert 86 Cutlass
Engine: Sbc
Transmission: T5 400 Turbo
Let me know your oppinions Dont worry they wont hurt my feelings I have alot of hard earned money and time into this car. Im not sure if i am or not just would like to have some other camaro fan oppinions
91 Camaro RS Convertable
355 5 speed 342 rear end
MOTOR/TRANS
76 350 2 bolt main
.030 over by well known machine shop locally
10.5.1 Flat Top Pistons
Eagle Rods/Crank
Comp Magnum 480/480 Cam/lifters
202/194 Valve Heads
Screw In Studs Tripple Valve Springs
Edelbrock Scorpion II intakte(victor jr)
Holley 750 DP Carb
MSD HEI DIST
MSD COIL
MSD CAP
New Plugs/Wires
Hedman Shorty Headers
Hedman Y pipe
Dyno Max Muffler
Chevy Valve Covers/Air Cleaner/Timing Cover
World Class T-5 Trans
Centerforce Clutch
Barry Grant Fuel Pressure Regulator
Electric Fan
Double Roller Timing Chain
Good Year Eagle Tires on Z28 Rims
NO RUST ON BODY... NO DENTS
Small spot of surface rust
99% PERFECT INTEIOR
AUTOMETER SPORT COMP 5" tach with light on face
HARWOOD 3" BOLT ON COWL HOOD
Tilt wheel all gauges in dash work except tach
perfect dash/console seats
NEW GM TOP $1000 NEW....
Clean car been wet sanded ready for your paint job
If I am selling I am asking around $6500
MOTOR/TRANS
76 350 2 bolt main
Eagle Rods/Crank
202/194 Valve Heads
Holley 750 DP Carb
MSD HEI DIST
MSD COIL
MSD CAP
New Plugs/Wires
Hedman Y pipe
Dyno Max Muffler
Centerforce Clutch
Electric Fan
99% PERFECT INTEIOR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
Engine: Sbc
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
Re: Thinkin of selling my vert
Personally like 80% of people that carb is way to big for a 355 you dont need that it prol run better with vacum secondaries 750 or a 650dp but thats a monster carb it seems..besides that looks like a good price how is the interior?
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Engine: Sbc
LOL there is a interior pic and info on that there lol
I have a dominator in a 383....
I also have stock 350s with 750 DP i guess its on the tune... The car still starves for gas at high RPM I am goin to a 850 sooon
Last edited by Gibbyzracing; Oct 29, 2008 at 10:02 AM. Reason: Automerged Doublepost
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
damn $6500 for a car that needs paint seems high but thats only considering i've seen complete cars that need no touch ups or work go for that or less money(non convertibles) are convertibles that more expensive, i plan on buying one eventually so please someone enlighten me
Engine: Cammed 6.0L LSX
Even though you may have more than $6,500 in the car, it is very unlikely that you actually get that much out of the car just because it's going to be very hard to find a buyer who can get past the appearance of the car. It definatly needs some attention on the body/paint, and it's hard to tell about the true condition of the interior. With that said, a potential buyer is most likely going to be turned off from the car with that price, needing a major paint job. I'm not saying the car isn't worth $6,500 because honestly I don't know. I've never seen a convertible sell for $6,500 that needed a complete overhaul on the paint job. I'm just saying you'll be hard pressed to find a buyer with the paint in that condition. My suggestion to you is to hit up Maaco and slap a cheap paint job on there for a few hundred dollars. It won't be perfect, but it will be just enough to get a few bites I think.
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
lol i meant like how is the interior since you can only see a little bit..like the rest rear trunk space back seats whatnot and he said give your opinions so grow up and stop flaming. i asked a decent question i didnt think was to hard to understand sorry i cant draw it out for you...and i gave my opinion about the carb which i think is to big i used a 650 dp on my 383 and its plenty fine.
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
And also, those wheels also came on RS's, so they're not really JUST Z28 wheels.
And furthermore...upon reading more into the description...(also mind you this is just my opinion, take it or leave it)...but because you claim that you spent $1,000 on a new GM convertible top, that does not warrant an extra $1,000 in value for the car. Myself along with others have replaced our tops for much much cheaper than that. An aftermarket top (that looks better than an original GM top by the way) can be had for less than $400. An even $400 will even get you a glass window, which many people including myself have done, and it looks exponentially better than an original GM top. So with that being said, I would not justify adding $1,000 to the value of the car because you spent that much on a top.
/my $0.02
/my $0.02
Car: 1991 Z28 Convertible
Transmission: 5 Speed
Do you still have the stock hood? Will it fit? I would try and get it back to an original look as much as possible. Many vert owners like the cosmetics of the vert over the raw power. Power is nice, but you seldom get the money back on that investment. The stance looks funny to me, maybe the tires are too tall or something. If you have 91 wheels, that would also help. I've seen them for as little as $150 a set.
The interior looks good, if it runs well and you can get it looking a bit less hodge podge you may get closer to what you are asking. Good luck.
Engine: Sbc
I dont have the stock hood. I said Im starting at 6500 taking offers. It will be painted by spring. And ready to go for way more
Stangski09
Nov 14, 2015 01:27 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
