vert jack accesories and mounting
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
does neone know how where the jack is suposed to go, what i have is the jack(ratchet style) eyelet bolt, and a spare tire that has to be deflated to fit in side compartment. How do u inflate it can of compressed air cig lighter compressor? I have seen some people have a pad in bottom of compartment for tire to sit is a vert suposed to have this? I know for sure i'm missing the extension and the wrench type thing what all and where do u need to store/change... mostly store... tire. a pic of jack mounted would be greatly app
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: vert jack accesories and mounting
Here's a pic of mine from my '89 IrocZ vert. It's original and never been used . . .
The stock jack is a screw type scisssor jack mounted beside the tire. I believe the tire/jack iron is behind the wheel. It's been years since I've scene it. Would need to take a closer look for any details.
Engine: 5.0 tpi
Axle/Gears: g92 b/w
awesome you have been a great help, i know it's kinda a hassle to get that plastic on and off. i tried to get that canister from gm but they said the didn't have it.... yep i figured i had the wrong jack as i couldn't get it to fit. It's awesome that u still have that can of air. now i can see what i need and how it fits at least i have the "tire"
Axle/Gears: 3.08
After 20 years, I wonder how good that can of air is? Not that I'd use it for snorkling in the pool!
I'm sure you can pick up tire inflator from just about any decent automotive store. Also a lot of places, stores, wreckers, etc, have similar jacks all over the place. Maybe even somebody here.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
If the CO2 cylinder has not already been used, it should be OK. I carry a simple 12 volt air compressor as a back up. There are small ones available that will fit in with the tire and they have the capacity to inflate the space saver spares.
Engine: 5.0 tpi
Axle/Gears: g92 b/w
thanks guys i'll probly just get a little compressor i think all i can get around here is like fixaflat and i really don't need to fix a flat well not really....
Car: 1991 Z-28 Camaro
Engine: L98 350/5.7L TPI
Transmission: 700R4 4 speed auto or 4L60??
I just traded for a 91 Z-28 and have been calling around to find a "can of air" for the spare. So far the auto parts stores either have no idea what I mean, or the old school good guys advise they don't have a source any longer. Anyone see a link for such an air canister I'd like to see it. I've had rotten luck with the cheap air compressors blowing lighter fuses.
Axle/Gears: 3.08
You could try http://www.fixaflat.com. Then you'd have the option of either using it to pump up your spare or the actual flat tire.
I couldn't find any can inflators that used only propellants.
Engine: 5.0 tpi
Axle/Gears: g92 b/w
i just got an unused spare tire canaster jar and all accessoried off ebay for 130 plus shipping (probly never use it though) i just saw an alumionum spare on there with the canister still atached to it
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
