'87 Iroc vert 3rd brake light source!
Old Feb 5, 2010 | 02:21 PM
jnman's Avatar
Car: 87 Iroc Z Convertible
Engine: 305 LG4
Transmission: 700 R4
Hey guys, the orignal 3rd brake light lens on my vert has a couple of blisters on it. I guess someone must have put the wrong bulb (to hot) at one time or another. I was bugging me so I started the search for another one. After a little research & reading treads here, I discovered the one on my car could be replaced with one fron a 85 -89 Lincoln Town Car! First picture is the original in the car. Second picture is out of the car Third is the replacement lens ($20.00 total off eBay).
Attached Thumbnails '87 Iroc vert 3rd brake light source!-100_1489.jpg   '87 Iroc vert 3rd brake light source!-original.jpg   '87 Iroc vert 3rd brake light source!-town-car-replacement.jpg
Old Feb 5, 2010 | 02:37 PM
jnman's Avatar
Engine: 305 LG4
Re: '87 Iroc vert 3rd brake light source!
Here's the tag on the back from the wrecking yard (bonnettesauto on eBay)! Mustang lenses were not the same for my application. By the way, the only difference between the two is the replacement has the ford emblem on the face of the lense that I will have to remove (sand off & re-polish). Should not be to difficult to do. Ford parts on a Chevy who would guessed! Thought this might help someone else.
Old Feb 5, 2010 | 03:14 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Yup mine said ford right on the lens so I wet sanded it off and polished it like new!!
Old Feb 5, 2010 | 07:00 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have a 1991 Firebird convertible and I have not been able to find bulbs does yours have like 5 bulbs
Old Feb 5, 2010 | 08:46 PM
88 IrocZ Vert's Avatar
i just use 194s and been good every since, the ones that are org used are 6 bucks each. f-that
Old Feb 5, 2010 | 08:51 PM
jnman's Avatar
Engine: 305 LG4
Mine uses only 2 T906 bulbs. I purchased another light that uses 5 bulbs but there were none included. It has the bar to put the bulbs into, just no blubs. If anyone needs this type light 3rd brake light let me know!
Old Feb 5, 2010 | 09:33 PM
Engine: LQ4 ls 6.0
6 bucks im out on that how long have you been using 194 bulbs I havent had a third brake light for 8 years now it would be nice to see it work again
Old Feb 6, 2010 | 01:40 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
should just replace with led's
Old Feb 8, 2010 | 12:40 AM
Engine: LQ4 ls 6.0
Do the Camaro and Firebird have the same type of light houseing and just have differant bulds the first guy that first posted said that a Town car light would work does that fit both the Camaro and Firebird??
Old Feb 8, 2010 | 06:10 PM
jnman's Avatar
Engine: 305 LG4
[QUOTE=Mirror Image;4428384]Do the Camaro and Firebird have the same type of light houseing and just have differant bulds the first guy that first posted said that a Town car light would work does that fit both the Camaro and Firebird??[/QUOTE
Mirror Image, I'm not sure if the Town Car housing will fit the Firebird. Someone with a 'bird might be able to look @ the pictures posted & give you that answer.
Old Feb 11, 2010 | 09:29 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It would probably depend on year, I know it looks different than my 1989, but from the pix I have seen it looks really similar to the 1986-mid 1988 type rear brake lens on the firebird vert.
Old Feb 12, 2010 | 11:28 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
it dont look any thing like the 88 to 92 light!! but nice job for the earler cars
Old Apr 5, 2010 | 11:58 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Very strange but today I looked at several 85-89 lincoln town cars at the junkyard and none had a third brake light that looked like that
Old Apr 5, 2010 | 12:12 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
And i was going to ask you to pick one up for me my82roc!
Old Apr 5, 2010 | 05:36 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
if you need lightbulbs go to RShack they have them for abotu $2
Old Jan 23, 2011 | 04:53 PM
Vertigo107's Avatar
Car: 86 ASC Convertible #90
Is there a particular trim model town car that this brake light came in? I was at a yard today, and none of the cars had this style housing..
Old Jan 31, 2011 | 08:50 PM
Vertigo107's Avatar
Anyone?
Old Feb 9, 2011 | 09:46 AM
Vertigo107's Avatar
Still Searching... Anyone have updated info on this?
Old Feb 9, 2011 | 11:49 AM
jnman's Avatar
Engine: 305 LG4
Vertigo107, all the info I have about the vehicle model is what was on the sticker from the wrecking yard. I started my search with the part number on the back of the old one. If you have the original brake light, use that number & do a google search & see what comes up. If you don't have the light, let me know & I'll get you the number off my old one.
Old Feb 9, 2011 | 04:24 PM
Vertigo107's Avatar
Jnman,
I hadn't tried that, but I did, and found one after changing my search words. THANKS AGAIN!
Old Feb 9, 2011 | 09:09 PM
jnman's Avatar
Engine: 305 LG4
Glad I could help you out. Don't forget, when you get it, to remove the `FORD' from the face of lense, LOL!
Old Feb 14, 2011 | 07:06 AM
rusty459's Avatar
Car: 87 camaro Convertible
Originally when the car was developed the light was designed off a Country Squire Station Wagon. So putting a ford light on it is not out of character.
Old Feb 14, 2011 | 09:18 PM
Vertigo107's Avatar
Yeah, I actually looked at my original today under a light, and I can see the Ford emblem where is wasn't completely sanded off. The new one is from an 86 Crown Victoria, and is in fair shape. I wish I could take the entire ting apart and really get it clean, that would be awesome!
Old Apr 2, 2013 | 10:07 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
TTT
Jae992
Aug 27, 2015 09:07 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
