Converting the vert to stick shift. Should I?
Old Aug 26, 2010 | 11:05 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi guys,
I have managed to get hold of a manual car and strip the box out ready to transfer over the 87 hydraulic set-up T5 to my Vert 700r4. The manual box I am using was rebuilt 1k miles ago so its a good one but non-WC.
I have heard a few people talkoing about how rubbish the stick shift was for our cars and now I'm wondering if I'm doing the right thing? I want to enjoy chosing gears and holding it in 3rd from low speeds- you know the kind of thing.
So talk to me? Should I stay Auto or go manaul.
The car is a weekend and summer car so no daily commute.
Old Aug 26, 2010 | 11:34 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: Converting the vert to stick shift. Should I?
For just a fun summer car, YES! They are much funner to me, and connect you more to the car. Besides, a 305TPI, vert, 5 speed is a VERY cool combination.
With a relatively stock car I would bet the tranny would be OK for a while as well...
Old Aug 26, 2010 | 12:00 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Im also thinking about doing the same with my vert.I have a WC T-5 from a 92 Trans am and was able to get all the odds and ends from a 92 RS LO3 M5 car at a local yard.
Old Aug 26, 2010 | 02:22 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks for the support guys. For a fun car, manual/stick shift works. Most of the hard work is getting all the little pieces like the pedals, reservoir etc. Later on could always drop in a T56 or similar.
The auto box is gorgeous- very smooth BUT I want to drive this car at weekends, like I say hold it in gear and floor it when I want in what gear I want.
I heard chaning the shifter itself is a good move?
Old Aug 26, 2010 | 02:23 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
And just to add, I will keep motor pretty stock. Losing some weight and less drivetrain loss is a good thing
Old Aug 26, 2010 | 02:33 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm going to be swapping my 700 for a T5 here possibly this weekend. As far as I'm concerned; any manual swap is worth it in these cars!
Old Aug 26, 2010 | 02:51 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Great move. You wont regret it.
Old Aug 26, 2010 | 04:57 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Do it
I did mine to a 5 spd, then later on swapped in the 6 spd.
Well worth it IMHO.
Old Aug 26, 2010 | 10:07 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I changed mine from auto to 6spd, loving every minute of it.
Old Aug 26, 2010 | 10:48 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Theres only one thing better than driving a convertible 3rd gen, and that is driving a convertible third gen with a manual transmission.
Do it, and never look back.
Old Aug 27, 2010 | 09:50 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
The trick to the T5's longevity is to use it but not abuse it.
Old Aug 29, 2010 | 09:12 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
bangin gears is the best.do the swap i did too
Old Aug 29, 2010 | 10:54 PM
Midwest Muscle's Avatar
I've owned a number of 3rd gens, but never a convertible or manual. As of five days ago, I've covered both bases ... Bought a '92 Z28 droptop 5-speed. Not sure which part is my favorite - Putting the top down or shifting through the gears. I've owned a few late-model 6 speed rides, but the combination of 'vert and shifting is the best I've had yet!
Mike
Old Sep 24, 2010 | 06:54 AM
JWKbride's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
FWIW Hawks carries some parts for the swap, both interior and exterior.
3rd Gen Shift plate for console (6 speed swap)
You can go here. http://www.hawksthirdgenparts.com/co...ponents_1.aspx
More interior and machanical parts for swap you can go here: http://www.hawksthirdgenparts.com/ls...omponents.aspx
Old Sep 24, 2010 | 08:03 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
You`ll enjoy it! Do it, I would! Now if I could only find out where the wife took off too with the 88 vert 5 speed havent seen her all day!
Old Sep 25, 2010 | 02:15 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That's not even a question, YES.
Unless you're missing a leg or you knees don't work cruising in a 'vert thirdgen is just more fun with a stick.
Old Sep 27, 2010 | 08:42 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That is for the Firebird shifter plate, I am not sure what hawks is doing for camaros... Actually the new shifter plate look better than that one... The numbers are actually like the original Pontiac font.
I am not sure what
Old Oct 27, 2010 | 01:47 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
I was thinking of doing this swap to my 91 vert. However I heard that with the 1st gear in the T5 is a little taller than the 700r4, and that the 4th (OD) gear in the 700r4 is taller than the 5th gear in the T5. So basically the T5 has a smaller range of gear ratios. Is this true?
Old Oct 27, 2010 | 08:45 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
what a wait of time ,buy a 5 speed hardtop tpi camaro and beat the **** out of it and be happy with what you got and if you want go find a rs 5 speed car convertible be a lot cheaper if it came from the factory a manaul leave it that way and if it came with a auto than leave it that way to much work do with it what you want its a shame no wonder way theres so many none matching # camaros left. I prefer my all car stock like the way they were met to be .I have both a 1989 hardtop 5 speed tpi 1le car with 345 gears and a 305 tpi 230hp and love it and then for real power have a 1998 ss covertible camaro with the ls1 thats a real engine not those low power 305 and 350 made back in the mid 80s-90s also have a 1990 irocz camaro convertile (auto) for cruzing around So if you really want too do it right put a LS1 6-speed in it and that will blow the door off camaros and vetts
Old Oct 28, 2010 | 12:09 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are you drunk?
Old Oct 28, 2010 | 12:27 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes to the conversion, however you have a non World Class T5 there. They didn't start putting the better WC (World Class) T5 in until the 1988 model year. I converted my 90 RS to a WC T5 several years ago and am very pleased with the results. You should cut the reinforcing piece that surrounds the transmission tunnel hole from the T5 car and have it welded to the new car. Since you have the donor car you'll be able to take the measurements to cut the hole for the stick shift in the proper location. There are some wiring changes required and a chip difference between the auto and T5 version too.
Lon
Old Oct 28, 2010 | 04:55 AM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
What sort of twatt would call the manual rubbish? There is nothing more fun than banging gears with the top down! And seriously the T5 is a great transmission smooth shifting and dead reliable if you dont beat on it "too" hard
Old Nov 1, 2010 | 06:53 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
LOL- Americans use the word **** too! brilliant.
Car is going in next week for the swap.
As for the guy that ranted about non matching number Camaros. I would prefer to have a car that absolutely ticks all my boxes and enjoy driving it than having a car that is numbers matching. I didn't buy my car to speculate and sell on, I bought it to enjoy and drive.
Old Nov 1, 2010 | 11:34 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I swapped to a T5 in my 91Z28 a few months back and its a LOT more fun to drive... If you bought the car to drive, swap it; if you bought it to look at, keep the auto.
Old Nov 1, 2010 | 02:40 PM
Engine: LB9
Well actually we don't... the guy that did use that word is Canadian LOL.
Anyway, I agree with ya 100%. I bought my car to enjoy... it's by no means a garage queen (its actually lucky to spend a night in a garage) and I have some plans for it. Mine's a 1 in 555 Trans Am convertible too. However when I do start replacing parts, especially major stuff like the engine and trans, I plan on keeping the originals in case these cars do go up in value and if I'd want to ever sell it (the latter is very unlikely though lol). Probably saran wrap em and stuff em in my shed.
JK about the first statement though, I use that word occasionally.
Old Nov 1, 2010 | 10:14 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Old Nov 2, 2010 | 05:04 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Canadians/Americans- same thing..
Just joking
Old Nov 2, 2010 | 10:23 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
I use every "expletive" I can get my hands on, all the time. I've even adopted some of your favorites, like rubbish and ghastly.
Go for the swap. You won't be disappointing and you might get a few more mpg out of it.
Old Nov 28, 2010 | 12:14 PM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
I was wanting to do the swap myself, with a hydro clutch,
can anyone give me a list of EVERYTHING needed tobe done? kinda like a Guide on how to?
i'd really be greatfull.. im looking to do all of this in the winter months that way when summer rolls around its top down and baggin through the gears blasting motley crue!
oh also i wouldnt be getting the WC T-5 id do the T-56 swap if anything,
Old Nov 28, 2010 | 01:24 PM
Engine: LB9
Here ya go:
https://www.thirdgen.org/manualswap
http://www.skulte.com/T56.html
and the page where i got both of these from:
https://www.thirdgen.org/technical-articles
Oh and search the forums here... you're bound to find oodles of information since these are such popular swaps.
Hotrodboba400
Dec 10, 2019 07:07 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
