convertible rattles
Old Sep 28, 2010 | 04:12 PM
Sha-zam's Avatar
Car: 1989 Camaro Iroc-Z Conv
Engine: 305 (LB9)
Transmission: M5
Axle/Gears: 3.08
convertible rattles
I have an 89' Camaro convertible - the top rattles a lot while driving, it's a real pain . I'll be replacing the top next spring as it is due. Any suggestions what I can do to reduce the frame from rattling.
Old Sep 28, 2010 | 05:02 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: convertible rattles
There is a TON of really good info at the top of this forum. You've come to the right place if you want to know anything about your third gen. Welcome to the boards!
Old Sep 28, 2010 | 06:34 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Your first step is to determine exactly what part is rattling on your top before anyone here can tell you how to remedy the issue
Old Sep 30, 2010 | 06:43 PM
kymission's Avatar
I found that the best thing to stop conv. rattles is to replace the bottom seal that goes across the bottom.
Old Sep 30, 2010 | 07:02 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
I've had 3 convertibles, 2 full size and this Fbird, they all rattle shake and flap.
Old Sep 30, 2010 | 07:17 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think the nature of having a rag-top is having parts and pieces that have minor flaps, rattles and shakes. There is less structural rigidity than a coupe, or even T-tops and those are prone to their share of rattles and squeaks.
There are definitely things that will always rattle and shake and squeak, and other things that should not, so figuring out what you can do and how you can improve the car.
Honestly my car has a little noises, On the hand if you ignore the obvious road noise from only having fabric between me and the elements, For rattles and squeaks its actually quieter than some of the other 3rd gens I have owned. Unless I roll down the windows, then I get this "Snap" sound coming from the RH rear of the car...
But its a 36K mile car, vs 100+K mile cars I have otherwise owned...
As a suggestion Have someone drive around while you sit in the back seat to search for where the noises are coming from...
FormulasOnly
Jul 23, 2018 08:47 AM
jrdturbo
Mar 31, 2016 02:58 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
