Convertible - 2 post lift?
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
stupid question of the day - can you setup a convertible on a 2 post lift?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Convertible - 2 post lift?
All the 2 post lifts I've ever seen actually had 4 arms that swing under the car, so there are 4 points of contact anyway. Never seen a 2 post lift with just 2 arms, that would be scary in my book! Car would act like a teeter totter!
By "set up" do you mean installing suspension or SFC's? I always thought you wanted suspension loaded for SFC's and such?
Engine: 5.7 L98
yeah i mean 2 post 4 contacts so, i believe some corvet convertibles have to go up on a ramp, so wasnt sure about the convertible third gen
Car: 1992 RS
Engine: Carbed 350
I thoroughly understand your concern with the vert - given the unibody and the flex I feel in my T-top car and also felt in my hardtop car. For oil changes, etc. I wouldn't have concern, but for suspension setup, I'd want a ramp lift regardless of being a vert or not.
Engine: 5.7 L98
when i get my sfc's welded in im sending that to a body shop so im gonna assume they know what do..... i hope
Car: 1992 RS
Engine: Carbed 350
Shocks/struts/springs there's no room for error - they only go in one way, no need for any load or preload.
Same for ball joints, tie rod ends, centerlink, idler arm, A-arms - no need for any load or preload.
Sway bar end links should be installed under load I think, but doesn't matter on sway bar bushings. No need for load on panhard bar, or torque arm mounts either. LCA's I don't know about, but can't see how it would matter.
But SFC's definitely want to have the car straight when welded, whether that means loaded or not I'm unsure, I would assume loaded (on all 4 tires).
