Pics of factory speaker rear speaker grilles OE
Old Jul 6, 2012 | 03:27 PM
BADNBLK's Avatar
COTM Editor
My car had a "sweet" set of 6x9 hacked into the rear speaker panels, and I have no clue what they looked like. I can see that they were square, but might try and "match" the look with a square 6x9 speaker grill.
Any pic of Camaro factory speaker grills would be appreciated
Old Jul 6, 2012 | 04:26 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: Pics of factory speaker rear speaker grilles OE
front
back
Old Jul 6, 2012 | 04:32 PM
BADNBLK's Avatar
COTM Editor
That is awesome!!! Thank you! Is that fabric covering the plastic?
Old Jul 6, 2012 | 06:56 PM
sid rs91's Avatar
Transmission: wc T5
Any time
Yes that's fabric.
Old Jul 9, 2012 | 02:59 PM
BADNBLK's Avatar
COTM Editor
So I think I'm gonna try and get these and find a mesh type fabric to cover the grills with some new aftermarket speakers behind them.
http://www.ebay.com/itm/BLACK-DELUXE...s_Gear&vxp=mtr
Old Jul 10, 2012 | 12:49 PM
BADNBLK's Avatar
COTM Editor
Well I ordered those speaker grilles above and some fabric in attempt to replicate the factory look. I will post pics, and if it turns out good maybe other can use this as an option too.
Old Jul 10, 2012 | 06:24 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
The 6X9 fit in the vert?
Old Jul 10, 2012 | 07:43 PM
BADNBLK's Avatar
COTM Editor
I guess so...
Old Jul 10, 2012 | 08:38 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Convertible cavaliers and sunbirds of the same years use the same speaker grills as the Fbody.
Old Jul 10, 2012 | 08:56 PM
BADNBLK's Avatar
COTM Editor
My concern with that is that they would not fit over a 6x9
Old Jul 10, 2012 | 09:02 PM
TTOP350's Avatar
mount the 6x9s on the back side of the trim panel so it doesn't look modded or rigged.. ;-)
Old Jul 10, 2012 | 09:53 PM
BADNBLK's Avatar
COTM Editor
I probably will if there is still enough room
Old Jul 17, 2012 | 01:25 PM
BADNBLK's Avatar
COTM Editor
Got my grilles and fabric. I'm mounting the screws into the covers and epoxying them into the covers, so when covered with fabric it will still have that OE look... just a little bigger.
Old Sep 12, 2012 | 10:17 AM
BADNBLK's Avatar
COTM Editor
I got one of the speaker covers finished and installed last night. Looks much better than an eye sore dirty 6x9 hanging out of the panel. This looks better, but def not an OE solution
installed...
Old Sep 12, 2012 | 06:35 PM
Stauf's Avatar
Car: 91 Z28 Coupe
I believe the originals were a 5x7 hybrid, used by GM. 6x9s will fit, you just have to move the speaker towards the rear a bit to miss the support strut in the verts.
Old Aug 24, 2018 | 09:12 AM
V8SC1987's Avatar
Car: 1988 Camaro Iroc-Z Convertible
Axle/Gears: 8.8 with 4.10 Gears
I know this thread is insanely old, but there aren't too many people doing this kind of thing... I have the same problem and I'm looking to do something similar myself. The question I have is, did the indentions from the speakers ever relax? If not, I'll be looking for a way to make that happen since I'm hoping to get a solution that looks as OE as possible.
Old Aug 26, 2018 | 08:11 PM
Sweatlock's Avatar
A cheap hot air gun from Harbor Freight and playing it over the vinyl on low heat should do the trick. Don't get too close and move it around over the indentation to avoid burning anything. These hot air guns come in handy for electrical work too (heat shrink tubing). I don't buy a lot of tools from Harbor Freight, but mine works great.
Old Sep 2, 2018 | 07:33 AM
sgeorges714's Avatar
Car: 1987 Z28 Vert Special Edition
Engine: 305 TPI LB9
[QUOTE=Stauf;5377299]I believe the originals were a 5x7 hybrid, used by GM. 6x9s will fit, you just have to move the speaker towards the rear.
I initially tried several shallow 6x9 speakers but no luck. Quite a few recommended a 6.5" speaker with an 6x9 adaptor and those worked like a charm. No carriage conflicts at all. Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
mustangman65_79
Aug 12, 2015 06:39 AM
