subframe pictures
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
subframe pictures
All you vert guys with subframe connectors please post pics and what kind you bought. I have heard that some of you have installed two sets at once which Is what I will probably do. Please post pics and what you guys think fits and works the best. The crack in my windshield is due to body flex and I can hear it grinding and popping whenever I play with it on my curvy road to my house. It must be fixed since I am not going to buy a windshield every month. Thanks in advance guys.
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Re: subframe pictures
I just got the Alston Racing connectors installed on Friday. It's like driving a different car, no more creaking when I go down my driveway or over sidewalk ramps.
I had a hell of a time getting them installed. Took them to one body shop, they called me back an hour later and basically told me to come pick the car up; they were not interested in doing the work. Took them to another body shop, they did the work, but claimed the cat converter had to be removed. I was not crazy about it, but I told them to go ahead. I'll probably try and replace it soon, but for now it's gone. Anybody else had this issue with the Alston's?
Here is a lousy picture I took yesterday. It's the best I have, so it will have to do.
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
i've got two sets. was supposed to install them this weekend.... but somehow in replacing my valve cover gaskets, plugs and plug wires my car won't start and made a loud metalic bang sound.... so i'll be tearing into to it again figureing that out instead of insalling my subbies.
Spohn
Aliston
Spohn
Aliston
Show me pics of your set-up. My car flexes so bad I cracked my windshield. I fixed the suspension this summer with all red sway bar bushings, shocks and struts, control arms, panhard bar, etc and now IT HANDLES!!! but it also cracks windshields and before I get a new one I got to fix the flexing problem. Some of the guys got two sets installed which is what I want to do but I need to know what sets fit and what sets will not fit. I have UMIs welded on my 90 t-top iroc and they are great. I put the floor jack under them and jack the car up by them.
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
I installed the Alston's connectors in my garage while the car was standing on the jack and candles, nothing hars. It took my friend & I about 1 hour 1/2 to bolt them without any major issue! After, I went to my friends shop to have them welded. Now feels like day and night compared to factory driving. But if you do any major engine modification and increase your torque significantely, you can surely add the Spohn connectors for a complete frame reinforcement. I will add them this coming winter, and if you do so, order them bared metal because you will have to weld them all along the perimeter so basically, the money invested in powder coating is a waste in my opinion, just paint them on place after the welding process...
Just to let you know, Spohn performance drop their price on black friday and during Christmas time too!
Car: 92 Trans Am Convertible
Engine: 5.0L
4-21-09
Added Sub Frame Connectors [SFC]
I purchased the SFC and a Wonder Bar from Lon at Top-Down Solutions www.top-downsolutions.com 626 369 0040 and they are awesome.
I had Certified Performance at 2900 Woodson 314 423 1663 Weld them in and throw on the Wonder Bar while they had it on the lift.
and it made a HUGE difference!
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i have the alstons.they work well but drag on tall speed bumps and im at stock height.
Car: 88 Iroc Convertible
Guys where is the best location to install these sfc? If you were doing in in your home garage did you use ramps etc. Or is it better to go to a local shop?
Go to a muffler shop or a shop where the car is resting on its wheels and not on the swing arms positioned under the frame. The car needs the weight on the wheels for the SFC to be at there best. If the car is at home and you use 4 car ramps and have the ramps under each wheel then you are good there also as long as the weight is on the wheels.
HI Guys has anyone heard of, or have used SFC's from Competition Engineering by Mororso? Bolt or welded? I have a local shop that uses that company but I dont see it being mentioned on the forum. Tks
Car: 1989 iroc convertible
Engine: 305 tpi
Transmission: 700 r4
Hmm 2 sets of connectors? mine go in on monday (single set umi) . I would like to see picts of how to install 2 sets aswell someone post it please.
Linson
Sep 21, 2015 01:08 PM
Street Lethal
Sep 7, 2015 01:09 PM
