leaving doors off?
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
leaving doors off?
Hey guys, I was just wondering if it would be a bad idea to leave the doors off in my Trans Am convertible for an extended period of time. I'm in the middle of doing body work and paint soon and I'm replacing the passenger side door and fixing the driver's side door. It's easier to do body work on a door (for me anyway) when it's off the car and facing up, plus I got to repair the hinges, replace a small section of the driver's side floor, and do other things. I'm just a little nervous about the structural integrity of the car, seeing that the doors help stiffen the chassis and it's already missing a solid roof to hold it together. Thoughts? Thanks!
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: leaving doors off?
I wouldn't worry about it too much. The chassis will flex a bit here and there with the doors off depending on whether it's on jackstands or it's wheels, but once you get it back together and get the doors on, it will all "settle" back to where it's supposed to be.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
With SFCs I think it'd be ok but I wouldn't do it without them unless you meant only 1 door at a time & just long enough to do the bodywork & hinges then put the door back on. Then the other side.
Car: 1986 Trans am
Engine: 5.3 LM7
Converts have factory subframe connectors. My T-top TA was in the garage on jackstands with both doors off for about 2 years, and now that it's back together, it's still straight as an arrow.
Car: GTA
Car: 1986 Trans am
Engine: 5.3 LM7
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would think (think) that you would be fine as long as you do not go driving it around... The T-top cars (and obviously Convertibles since they were converted T-top cars) had the extra wedges to move the stress further up on the body...
John
John
Engine: LB9
Thanks for the feedback guys, and yeah the car won't be moving at all, except for maybe a few feet at a time when I move it around the garage. I'm assuming I'd be OK jacking up one end of the car too? Like to swap a rear end and possibly drop the fuel tank....
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
