frame connectors
Old Oct 5, 2013 | 01:10 AM
mikesz1984's Avatar
Car: 1984 z28
frame connectors
I am ready to order the frame connectors for my 1992 and when I search on here everybody says that the mac and alston connectors are the same. But when I go to Macs site it says there connectors are not for convertibles. Has anybody succesfully installed them on a vert.
Old Oct 6, 2013 | 07:24 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: frame connectors
why not just buy the alstons?macs cheaper?btw mine drag on tall speed bumps and im not lowered.not a problem unless you want to lower your car.
Old Oct 6, 2013 | 11:47 AM
mikesz1984's Avatar
Car: 1984 z28
Its not a matter of price the macs are cheaper but I can buy those from a local place. The alstons I would have to have shipped and the price for that is close to $80 to come to canada
Old Oct 25, 2013 | 12:27 PM
V8SC1987's Avatar
Car: 1988 Camaro Iroc-Z Convertible
Axle/Gears: 8.8 with 4.10 Gears
If you have to have them shipped UMI claims that theirs will fit convertibles.
http://umiperformance.com/catalog/in...roducts_id=127
I have been told them that they fit nicely. I guess I will see when I get around to installing mine.
Old Oct 25, 2013 | 01:30 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
It's bad enough hard top guys debate this, but I can at least understand it since they have zero SFC's from the factory.
But if you have a convertible why on earth would you waste money on putting SFC's RIGHT next to SFC's. That just results in a slight stiffer connection in the same area you already have one.
You wouldn't bolt a strut tower brace to both the front and back of your strut tower would you?
Get the alston's that run down the middle and truely connect the front and rear subframe plus you'll also have the stock ones. So now you have 4 evenly spaced subframe connectors under your convertible.
I run them on both my t-top and vert.
Pic of them on the convertible can be seen in my post here.
https://www.thirdgen.org/forums/fire...-firebird.html
Old Oct 25, 2013 | 04:35 PM
V8SC1987's Avatar
I guess it always depends what you're looking for. I have long tube headers and it doesn't look like those alstons allow for much room to run the exhaust. Ground clearance is at a premium as it is for these cars so I want to be able to tuck my exhaust up as much as I can. Do you have any photos of the stock subframe connectors on your car? I have only seen additional rocker panel reinforcement on my vert, but that doesn't really tie the subframe together.
With all that being said, the alstons do look like nice pieces as well.
Old Oct 26, 2013 | 05:34 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have UMI weld in SFC on a t-top car and you can use them to jack up the car with a floor jack which comes in very handy. They stiffened up the car very well also.
Old Dec 29, 2013 | 10:38 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
MACS are weld in only, Alstons bolt in, hence the slightly higher cost. Otherwise, they route the same.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
RS Reaper
Sep 27, 2015 07:04 PM
