A-Pillar Gauge Pod
Old Mar 30, 2009 | 08:48 AM
FLYNLOW92rs's Avatar
A-Pillar Gauge Pod
I know they make a verion for hard/t-tops, is there a version for the vert? Or do you just use one of the t-top version?
Old Mar 30, 2009 | 10:00 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: A-Pillar Gauge Pod
Why do you ask....did you get another thirdgen??
Old Mar 30, 2009 | 12:29 PM
Sure did, a vert this time....
Old Mar 30, 2009 | 02:42 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
get the t-top version and trim it it will fit good.
Old Mar 30, 2009 | 06:33 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
NICE! Whatever happened to your old camaro?
Old Mar 31, 2009 | 10:39 AM
My86'stitsRout's Avatar
Car: 65 SS Impala,86vertZ28,88vertIrocZ
Engine: Stock 305 TPI
Transmission: 700R4 Automatic
Axle/Gears: Stock
post some pics when you install it i'm thinkin about doin the same to mine
Old Mar 31, 2009 | 11:27 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I already did this a long time ago. Many others have too I believe.
You just buy the part for the ttop cars, and cut off the end of it so that it will fit the convertible pillar. A good thing about doing this is that it looks much more factory than one of the pods that you drill onto an existing pillar cover.
The pictures may not be the best, but you can see how it looks like it came that way from the factory.
Old Mar 31, 2009 | 01:26 PM
Sorry those pictures are blocked, but does a triple gauge pillar work or does just the dual gauge one work?
Old Mar 31, 2009 | 02:15 PM
jstoltz's Avatar
either one will fit
Old Mar 31, 2009 | 02:42 PM
BlueZee28's Avatar
The pictures work for me, even on my phone. Did you try refreshing the page?
And I've never seen a triple pod on a vert. Considering the bottom guage on my pod touches the dash pad, I wonder how well a triple pod would fit.
Old Mar 31, 2009 | 03:07 PM
I'm at work, it's blocked......
I seem to recall seeing a triple pod on a vert before? Has one been done before?
Old Mar 31, 2009 | 03:50 PM
jstoltz's Avatar
they worked fine for me too. I think the bottom sits the same on the triple guage pods. It didn't look too good though just because it took up the whole a pillar. The dual pod is all I would do.
Old Apr 2, 2009 | 05:26 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I hate how the bottom pod sits on the dash. It's absolutely stupid that Autometer and all the others did that. My dash sits about 1/4" high on that side and none of them fit. I'm going to get the 2 pod add on type and then adhere it to the stock pod without screws. Hopefully it will look good.
Old Apr 2, 2009 | 05:33 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
it looks good but i hate that steering wheel. i had a 91 as well as my 90 and that has to be the uglyist wheel i have ever seen. i want to get rid of mine.
Old Apr 2, 2009 | 08:00 PM
BlueZee28's Avatar
I wonder why your dash sits high? Does it have aftermarket speakers underneath? I suppose you could just trim off some of the underside of the pod to make it work. I didn't want the add-on style because it doesn't look factory.
See, I tend to think the pre-'90 style wheel is the ugliest thing ever.
Old Dec 29, 2013 | 09:06 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Reviving another old thread, I know, but I'm a big proponent of the method. Anyway, this looks great! I see the bottom is close to dashpad, does it press the pad as much as the triples do? I had a triple in my last Iroc and hated how it compressed against the dash pad, even after I trimmed the top of the pillar pod some to slide it up. Only need a dual pod this time though so hoping fitment is a little better, or are they the same and Autometer just adds a third to the top of the row for their triple?
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
