sunvisors
Old Nov 27, 2014 | 05:18 PM
jovibuilt's Avatar
sunvisors
Do top visors fit a vert?What will interchange?
Old Nov 27, 2014 | 06:56 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: sunvisors
You will need a pair of the curved T Top visors.Hardtop visors will not work
Old Nov 28, 2014 | 02:18 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: sunvisors
If you cannot find a pair, make them yourself by using the originals as a form. All you need is some material and a needle with thread. After removing the originals from the car by loosening the screw that attaches them to the post on the car, cut off the old material carefully and lay it out for a pattern to cut the new piece. Cut out a new peice of material and then sew the edges around the old cardboard piece to make the new one.
Old Nov 28, 2014 | 04:54 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: sunvisors
I'd love to have visors that don't have the two inch gap at the outside.
Old Dec 1, 2014 | 01:39 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Re: sunvisors
Then custom build them to your liking.
Old Dec 4, 2014 | 09:28 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: sunvisors
You can get the cardboard from most upholstery shops, and then cut it to fit. To get a form I have seen where people have somehow got the board soaked and then forced it into the shape they wanted, then let it dry completely... Could put it in an oven at 150°F - 200°F or so to dry it out.
I imagine there is a process, but that would be where I would start. The board has to be soaked to where it it flexible.
I got some aftermarket sun visors and they did not quite have the shape of the originals, but they were ok...
Old Dec 9, 2014 | 09:27 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: sunvisors
Can also use 1/8" hard board, they sell in 2 x 4 sheets at homedepot
Veaceonee
Sep 29, 2016 08:15 PM
camarosource
May 27, 2004 01:07 AM
srcamaro
May 14, 2004 02:00 PM
MYROC19
Oct 19, 2000 03:46 AM
