Convertible stock sub frame connector?
Old Dec 12, 2014 | 08:53 AM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Any convertible owners on here with bone stock cars? Post up a pic of your pinch rail area please. My 1991 Firebird has a box riveted to the floor on each side over this area. Just wondering if its stock.
Old Dec 12, 2014 | 10:44 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Yes,that is stock...I don't have any pics of my 3 verts in that area but they all have the same thing.
Old Dec 12, 2014 | 11:05 AM
Re: Convertible stock sub frame connector?
OK thank you. Then when I replace the floors they will get solid welded.
Old Dec 12, 2014 | 12:07 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I would add real sub frame connectors. They would do a much better job.
Old Dec 13, 2014 | 08:43 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yep thats stock. Personally if you are replacing your floors Id get rid of the stock angle they used riveted to the floor. Then do a set of perimeter SFCs and a set of inner like the alstons for verts.
Old Dec 13, 2014 | 12:55 PM
If you do use sub frame connectors on the perimeter of the floor, I would use the beefiest ones that I could find. I used Competition Engineering on my old 84 Camaro and they were great. But that was when they were much larger and stronger.
Old Dec 23, 2014 | 01:31 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I believe the Spohn & BMR will work in conjunction with the factory riveted ones. I'm currently running stock and Chris Alston inners, planning to add outers in the springs.
Old Dec 23, 2014 | 01:36 PM
OK thank you all. Last weekend I got a set of begs outer connectors for a hardtop for $100 so I will be modifying the stock ties to work with those.
Old Dec 25, 2014 | 12:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If you are referring to the Alston SFC's I sell, they are made by Alston Racing in Illinois (now part of Heidts), not Chris Alston Chassisworks. It was one company many years ago, but they have been separate companies for a long time now.
Lon
Old Dec 25, 2014 | 12:35 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
Alston then, mine are from Jeg's. Look exactly the same as what you posted so guessing they're the same.
Old Dec 26, 2014 | 04:46 AM
I bought a set from Lon years ago and found his product and service excellent.
Old Jan 1, 2015 | 07:12 PM
Helmut's Avatar
Car: '88' IROC &'92 Z/28 both convertibl
Engine: 377 / 305
Transmission: 460 LE
Axle/Gears: 410 / stock
I have a set set that look similar, however they are to be welded for my convertible. For serious H.P., should I also consider the perimeter frame connectors also and once they are all welded in is there room for true dual exhaust? My Stefs oil pan goes to the frame leaving no room for cross over.
Old Jan 3, 2015 | 06:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
I understand that dual exhaust Is a a bad idea on our cars a.just use a a 3 or 4inch cat back.
Old Jan 3, 2015 | 07:38 PM
Helmut's Avatar
Engine: 377 / 305
I have to go back further because of the oil pan taking the space where the crossover goes. I have SLP stainless short headers. The exhaust will be worked out. The frame stiffness is my concern for now. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
