What is this molding?
Old May 30, 2015 | 08:33 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
What is this molding on the leading edge of the spoiler? I've seen it on a couple of convertibles.
Old May 31, 2015 | 06:31 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: What is this molding?
I have never seen that. I am assuming it may not be an ASC convertible.(which is all I am familiar with).Maybe some of the other conversion companies used it . In the pic I dont even see the third brake, unless it is hidden from the angle.
Old May 31, 2015 | 09:21 PM
my82roc's Avatar
Car: 89 Iroc Convertible
It is a plastic gasket filler piece.I grabbed one off a 91 rs vert that a friend was parting out as mine didn't have it.Im assuming it was used to seal out water from getting under the rear spoiler
Old May 31, 2015 | 09:32 PM
Stauf's Avatar
Car: 91 Z28 Coupe
That is what I thought at first, but it seems that there is a definite seam between the deck lid and spoiler. It could just be from the pic. Out of the 2 91-92 verts I have had, neither have had the gasket sticking out to that point. The gasket is there, but it is neatly tucked underneath the spoiler.
Old Jun 1, 2015 | 05:36 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
I have an 92 and it has this gasket .
Old Jun 1, 2015 | 10:41 PM
chazman's Avatar
Axle/Gears: BW 3.45
Does anyone have a picture of it uninstalled?
Old Jun 2, 2015 | 09:36 AM
yo soy el warg's Avatar
My 1988 and 1989 are both all factory original ASC convertibles and they have the same black weather bead as pictured above. My cars are both white so the black beading is easy to notice on them.
Old Jun 2, 2015 | 03:25 PM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
yes its a factory piece came with all verts. I took it off mine as I dislike the look but I seldom drive mine. It helps do deflect the water off to the sides as the verts have the trunk that acts like a giant water trap between the 2 rear side spoilers.
If its a daily driver prob good to have this.
Old Jun 2, 2015 | 03:38 PM
chazman's Avatar
Axle/Gears: BW 3.45
Got a picture of what it looks like uninstalled?
Old Jun 3, 2015 | 12:27 PM
madness's Avatar
Car: 1991 Z28 Convertible
Engine: 5.0 TPI
Transmission: 5 Speed
My 91 has it but it seems a tad dry and it does not extend to the ends of the spoiler so it seems water could get underneath? I would like to find another one or something similar to put in place of it.
Old Jun 3, 2015 | 03:05 PM
IROCNParts's Avatar
ya thats how they are, they dont make it all the way to the ends.
Old Jun 3, 2015 | 03:06 PM
IROCNParts's Avatar
I have one still on the black vert, Ill try to get it off and take a pic
Old Jun 3, 2015 | 03:52 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks!
Old Jun 3, 2015 | 04:39 PM
madness's Avatar
Engine: 5.0 TPI
Thanks for the info now I don't have to search for one.
Old Jun 4, 2015 | 05:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
My 92 T/A has this. It looks like a solid round bead with a flat section that slides under the spoiler lip. The flat section has a few angled slices cut in it for who knows why..
Old Jun 5, 2015 | 09:15 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I wish I could find one for my 89 Formula... Previous owner had removed it, or could not figure out how to reinstall it when they apparently changed the high-mount brake light.
Old Jun 5, 2015 | 10:50 AM
TTOP350's Avatar
It looks like miniature lawn/landscaping edging or a 9.
Old Jun 5, 2015 | 10:53 AM
TTOP350's Avatar
The 89s don't have this piece.
I'll try to get a pic an txt it to you of what it looks like.
Old Jun 7, 2015 | 01:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It originally did extend all the way across the trunk lid, but the seal shrinks from UV exposure over time.
Check with a convertible top shop for a replacement. I got some in red vinyl free off a spool from a local top shop. I put it on and decided the red looked OK, so I diverted from my original plan to paint it with black vinyl paint. I don't know what GM or ASC called it, but P-seal is a common name for this type of seal.
The slices on the end are to help it make the slight angle turn. The hard vinyl would not easily turn otherwise without bulging the flat portion.
Lon
Old Jun 7, 2015 | 03:31 PM
Stauf's Avatar
Car: 91 Z28 Coupe
The one 92 vert I had was black (all original), so I probably didn't see it. The second red 91, was a hack job from the PO, and repainted. So it probably trimmed down for the paint job
Old Jun 8, 2015 | 08:59 AM
okfoz's Avatar
Correct, on my 89, it was just under the 3rd Brake light housing. Same idea, it was a gap filler. I wanted to duplicate one, but I have no idea what it looks like. If I got an original, I should be able to duplicate it in Black Silicone...
John
Old Jun 13, 2015 | 02:36 PM
chazman's Avatar
Axle/Gears: BW 3.45
It's a P-seal. Comes in rolls and is something similar to this. http://www.ebay.co.uk/itm/P-Seal-Str...-/261339216790
I guess we'd need to know the proper size.
Old Jun 13, 2015 | 02:59 PM
TTOP350's Avatar
Pix from my JY 92 TA vert. (yes its nasty)
Old Sep 20, 2025 | 01:41 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
anyone find a source other than the open channel seal hawks has?
NJ92Z28
May 29, 2024 05:16 PM
Crouchman
Convertibles
40
Nov 2, 2017 02:49 PM
thatsme
May 10, 2006 06:54 PM
Doward
Aug 3, 2005 11:03 PM
