Top latch spring
Old Aug 25, 2016 | 11:47 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Top latch spring
I have a question about the convertible latch spring, I believe that is what it is called. It is the pseudo-clothespin shaped spring that holds the rear convertible latch pin secured.
My question is do they wear out, and where can I find a quality replacement? When I close the latch, it will occasionally pop out of place or when I do get it secured then it sometimes won't return to the correct position when I pull on the handle to open it up. Any thoughts/suggestions?
For reference, here is a picture of my assembly. Am I missing anything?
Old Aug 26, 2016 | 09:22 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Top latch spring
Is it possible that the pin is worn out?
Old Aug 27, 2016 | 09:19 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
It's possible that the part it attaches to is part of the issue. Have you checked that the lock is positioned correctly as well?
I've seen the pins broken off but there shouldn't be to much wear on the pin if positioned correctly
Old Aug 27, 2016 | 10:00 AM
my82roc's Avatar
That big cotter pin should squeeze the pin tight once it's inserted.
Old Aug 27, 2016 | 10:03 AM
rarebmx's Avatar
Mine isa latc, pin goes in, sing latch accepts the pin. Release the spring latch & pin pops out.
Old Aug 27, 2016 | 12:17 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
http://www.hawksmotorsports.com/cama...h-upgrade-kit/
http://www.hawksmotorsports.com/cama...se-rear-latch/
Old Aug 27, 2016 | 04:06 PM
I saw the stuff at Hawk's. I don't need the entire upgrade kit. Being a '92, it already has that design.
Old Aug 28, 2016 | 12:59 PM
Engine: LB9
Axle/Gears: 3.08
It has the cotter pin in the small repair kit. The second one isn't an upgrade, it's for repair. I'd replace the ancillary parts too. Either way, they have the cotter pin one way or another. Maybe call to see if they separate.
Kevman
Apr 14, 2016 06:59 AM
Johnny Import
Apr 3, 2016 10:19 AM
86IROC112
Mar 26, 2016 04:38 PM
db057
Mar 14, 2016 08:53 PM
colinfinkle
Aftermarket Product Review
Apr 14, 2001 01:40 AM
