Removing Tonneau plastic cover from metal panel
Old May 21, 2017 | 11:02 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
Hey there,
Looking to prep and paint the 88 IROC Convertible and want to do a good job... Advice from someone that might know how to remove/separate the black plastic/vinyl tonneau cover from the metal panel it is attached to?
I have done a search but no luck finding info... HELP!
Fivestar
Old May 22, 2017 | 11:01 PM
the_assman's Avatar
Car: 90 vert
Re: Removing Tonneau plastic cover from metal panel
it's glued down and would be hard to remove from the tonneau cover.
i'm in the middle of painting my vert and ended up just leaving it on and taping it off. it was being a real sob to get off without damaging it. i was able to get it loose around the edges and lift it enough to get the tonneau cover painted though.
Old May 27, 2017 | 01:58 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Are you replacing the rub strip as well? Doing so will give you a small edge to use for taping off the plastic cover.
Old Jul 20, 2021 | 07:43 AM
fivestar's Avatar
Engine: IROC V-8
Yes I will be removing the old original rub strip as well
Old Jul 20, 2021 | 07:45 AM
fivestar's Avatar
Engine: IROC V-8
Thanks, I guess leaving it and being careful to insure good prep and get the paint mist underneath that small area is going to be the challenge...
Old Jul 30, 2021 | 02:21 PM
Hylton's Avatar
Car: A Camaro of some sort.
3M sells decal remover in a spray can. You can give that a try. They also have a wheel that removes decals but not the paint.
Radiorick
Convertibles
Apr 14, 2008 03:32 AM
tweeker
Convertibles
Jan 31, 2008 06:00 PM
pgtr
Oct 11, 2006 06:44 PM
drtybrd
May 13, 2001 10:08 PM
