Where to buy parts?
Old Mar 18, 2018 | 07:49 AM
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Where to buy parts?
It’s the lower hex head bolt
And this is where it is!
Hey guys,
I’m up to the point of removing the convertible top from the car but there are a couple damaged pieces. One bolt is missing from one of the major pivot points at the rear of the hood and it looks like it’s stripped the cast aluminium on its way out.
I know what’s caused it though so once repaired it shouldn’t be a problem.
Obviously im going to have to tap the thread but I’m wondering whether you can help me locate an original bolt first to test it with a locktite type of material before I start drilling and tapping.
I’ve attached pictures of the offending item (on the opposite side so you can see what I need) and its location. Help would be greatly appreciated with this.
Old Mar 18, 2018 | 04:33 PM
91ragtopTA's Avatar
Car: 91 Trans Am convertible
Engine: LB9
Axle/Gears: G80/GU2
Re: Where to buy parts?
Can't quite work out what your asking? no missing bolts in either of the pics?
Old Mar 18, 2018 | 04:41 PM
I was attempting to demonstrate the component I need, rather than showing you a photo of a hole with nothing in it.
I can post the hole with nothing in it if that will help?!
Old Apr 7, 2018 | 05:10 AM
Anyone?!
Old Apr 7, 2018 | 06:48 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Try contacting Lon at www.top-downsolutions.com
He has some new and used 3rd gen ragtop pieces for sale.
Also check www.thirdgenranch.com
Old Apr 7, 2018 | 07:31 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
3rd Gen Parts
He is a member on here and he parts out old cars; That bolt I think you are only going to find on a junked or parted out car. That frame was made by ASC which is the company that made the convertible conversion.
Old Apr 7, 2018 | 09:40 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
That shoulderd (spl) pivot bolt your looking for is real $pendy at around $30 IIRC and seen on fleabay.
Contact Lon as he may have a better answer.
Old Apr 10, 2018 | 02:10 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I might have one.Not sure if I sold them all or not
Old Apr 15, 2018 | 05:36 AM
Did you find one?
Old Apr 15, 2018 | 02:26 PM
91ragtopTA's Avatar
Engine: LB9
Axle/Gears: G80/GU2
Perhaps having a couple made up at a local engineering shop would quicker/cheaper than hunting one down from the states and having it shipped.
Old Apr 16, 2018 | 11:38 AM
you’re probably right. I’ll look into it!
Old Apr 29, 2018 | 02:13 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Not directly familiar w/ the actual bolt.
But, could the OP get a metal bushing from a hardware store, and press it on to a standard bolt, to provide a "shoulder"?
Old Apr 29, 2018 | 02:35 PM
Its a simple hex head metric bolt with a shoulder section for the roof to pivot on. I’ll look into your idea though.
Old Nov 24, 2018 | 05:48 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You want these shouldered bolts with the hex head?
or I have seen them on flea-bay.
But they are quite $pendy!
Texas T/A
Convertibles
Dec 17, 2010 11:57 PM
juanillox8
Exterior Parts for Sale
39
Sep 26, 2010 04:52 PM
Gummie
Jul 20, 2009 06:25 PM
badwolf76
23
Nov 16, 2008 07:13 PM
