Confused...
Old Aug 20, 2020 | 05:50 PM
robdean24's Avatar
Car: 1988 Iroc-Z Z28
Engine: L89
Axle/Gears: 273
Confused...
I recently acquired a 03/88 Iroc Z28 convertible. It has an ASC tag that says April of 88. It has a B&M shifter in it. Is that stock? It also has a number plate under the hood on the rad support. 09 4016. Does that mean anything? Any theory is better than what I have now.
Thanks for your time.
Old Aug 20, 2020 | 06:29 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Confused...
The B&M shifter is not stock. Post a pic of the number plate you are asking about, that will help us identify what it is, if it means anything, etc
Old Aug 20, 2020 | 06:47 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
I can't seem to figure out how to upload a photo
Old Aug 20, 2020 | 06:49 PM
dagwood's Avatar
Top Answer: 1
Re: Confused...
Click on this little picture icon...
Old Aug 20, 2020 | 07:00 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
Must be my phone. It will not upload. I even tried as a file attachment
Old Aug 21, 2020 | 05:21 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
Old Aug 21, 2020 | 06:37 PM
dagwood's Avatar
Top Answer: 1
Re: Confused...
I'm not sure what those numbers mean. That spot on my 88 IROC is covered by the air intake. I'll have to look when I get home. My 88 was built in 4/88.
My 89 RS has 09 6451 in that spot
Old Aug 21, 2020 | 06:53 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
Old Aug 21, 2020 | 09:41 PM
dagwood's Avatar
Top Answer: 1
Re: Confused...
My 88 IROC had it under the air intake... It's a little dusty under that! Time for some cleaning lol
I love the blue IROC's. Nice ride!
Old Aug 21, 2020 | 10:09 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
What does that tag mean?
Nice car btw.
Old Aug 21, 2020 | 10:32 PM
dagwood's Avatar
Top Answer: 1
Re: Confused...
I did a search on here, and it looks like it's just a build sequence number.
And since Camaros and Firebirds both came down the assembly line together, the sequence numbers will not match the VIN, unless it is the very first car built for the model year. My 88 has a higher number than your car, simply because it was built a month later than yours.
Oh and thanks for the compliment on my car. I would like it a lot more if it was blue lol
Old Aug 21, 2020 | 10:37 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
I wonder how to find out about the build sheet for that production number I assume through ASC
Old Aug 21, 2020 | 10:39 PM
dagwood's Avatar
Top Answer: 1
Re: Confused...
Have you looked under the carpet for your build sheet?
Old Aug 21, 2020 | 10:47 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
I have not.. no need to remove it.
Old Aug 26, 2020 | 05:40 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Confused...
The ASC tag is showing the year and month the car was converted to a convertible in their shop.
Old Aug 26, 2020 | 05:51 PM
robdean24's Avatar
Engine: L89
Axle/Gears: 273
Re: Confused...
My car says April 88 on the ASC tag. That doesn't jive.
Old Aug 26, 2020 | 08:36 PM
dagwood's Avatar
Top Answer: 1
Re: Confused...
No, that radiator support tag has nothing to do with ASC. We have an 86 IROC-Z, t-top car at work with 26k miles and it has the same tag. It's just the build sequence number at the factory
Old Aug 27, 2020 | 08:29 AM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Re: Confused...
I was speaking about the ASC paper tag he found 0n the driver's door - not the metal tag you are speaking about,
FluffyK
Interior Parts Wanted
Oct 29, 2017 12:08 AM
gchu
Convertibles
Jan 18, 2004 07:09 AM
