Best Lowering Springs For A Convertible
Old Mar 19, 2021 | 07:44 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I'm planning to install lowering springs on my 1989 Convertible Camaro. I just found out that convertibles have "flatter" rear wheel wells and that there is less room for suspension travel than in a coupe. I understand that will limit my options.
Based on your experience, what lowering springs are best for use on a convertible. I really don't want any wheel rubbing issues that could compromise handling/safety. I'm currently running 255-40-17 tires but plan to upgrade to 275-40-17 at some point.
I already posted in the Suspension section. I though this would be appropriate to also post here since it is a convertible specific question. Thanks in advance for any replies. Also, pics would be much appreciated.
Old Mar 19, 2021 | 08:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Best Lowering Springs For A Convertible
I have Ground Control, you can adjust the height to suit your taste. Also running 275/40-17.
Old Mar 21, 2021 | 11:51 AM
Max's Avatar
Max
Thanks for the reply. I'll look into those.
Max
Mar 21, 2021 02:36 PM
Bohemian
Convertibles
Jun 1, 2014 10:57 PM
jer4251
Dec 4, 2004 09:10 PM
robs91conv
Mar 18, 2003 08:43 PM
BigL350
May 12, 2002 09:02 PM
