Tonneau hatch release problem
Old May 14, 2022 | 10:15 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
The tonneau release on my 1989 convertible doesn't release properly. One side will pop and the other side won't. Then I've got to go to that side and press down on the hatch as I press the hatch release button on the console.
I've lubed the latches but it still does it. What's my next move?
Old May 14, 2022 | 11:04 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
Re: Tonneau hatch release problem
you can try adjusting the side that doesn't pop, but it may need a new actuator for that side.
I thought my latch was bad, but it was just out of adjustment.
Old May 14, 2022 | 11:05 PM
chazman's Avatar
Axle/Gears: BW 3.45
What is the procedure for that?
Old May 14, 2022 | 11:08 PM
Drew's Avatar
My RS has always been like that. One hand on the tonneau pushing down lightly on one side, reach in and hit the button, and it opens right up. Don't press down while pressing the button and it'll never release. That work around beats pulling the manual release cables every time. An adjustment might fix it, but it's so easy to push down and relieve the pressure on the latch, that it's not worth disassembling.
Old May 14, 2022 | 11:26 PM
chazman's Avatar
Axle/Gears: BW 3.45
Sometimes the sides alternate, so you don't know which side of the car you should be on, or they both require a gentle push, which means you are going back and forth.I find it very aggravating.
Old May 15, 2022 | 10:50 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
are both solenoids working? I seem to recall these style solenoids needing to be cleaned where they bolt for the ground. they get poor contact and don't operate with full power
Old May 15, 2022 | 11:01 AM
chazman's Avatar
Axle/Gears: BW 3.45
Intermittently or alternately. I think I look into that later today.
Old May 15, 2022 | 12:00 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
My '89 IROC X Vert had the same problem. I removed the solenoids and cleaned the shafts, lubed them w/ WD40. I replaced the mounting screws with plated screws and sanded the body solenoid mounting area, to bare metal. I coated the mounting area w/ silicone grease, before re-installation. I cleaned and lubed everything that moved , blowing out the debris, then re-lubing.
I think (it's been a while) I adjusted per factory procedure. Work great now. IIRC I operate the release, w/ the engine running, to get the alternators 13.5 - 13.8 volts, not the battery 12 volts.
IIRC, I sprayed "Cable Lube" (motorcycle stuff) into the cables, and blew it in.
Old May 15, 2022 | 01:09 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks guys. I just lubed the actuator cables and all seems to be operating normally for now. Whenever I disassemble one of these, I am struck by how the ASC guys were a bit short of the craftsmen from Maranello. Lol.
Am I the only weirdo who touches up the screws with a flat black paint pen afterwards?
Old May 15, 2022 | 07:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
This is suppose to be the fix (starting from the arrow). I tried it, small improvement, but the panel was the main issue. Since its a different design from the later style.
Old May 15, 2022 | 08:58 PM
chazman's Avatar
Axle/Gears: BW 3.45
Great idea about getting more volts with the engine running.
Old May 15, 2022 | 10:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I did the same thing mikeceli did and also played with the adjustment on the two tonneau strikers. Positioned them so they don't rub against the latch and only touch the catch hook thing in the latch. That appeared to help as much as all the other stuff i did. I've been thinking of messing with the tension bars, as my tonneau seems to barely pop open when released by the switch. Which sometimes works on the first (flick of the switch), sometimes not. Something that seems to work when it wont open on the first try. Is flicking the switch in rapid succession 3-5 times. That works more often than one single flick, but i don't really like doing that. I have'nt tried it with the eng running though.
Old May 26, 2022 | 04:17 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Nope, I do that too and on my Vette when I removed the hideous mudflaps some of the screws in the well were scuffed so I pulled them all out, cleaned them, sanded them, screwed them into a piece of cardboard and sprayed them with trim black…
Old Jun 8, 2022 | 09:28 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Charlie,
My 89 had this issue, I was able to get it to work better by adjusting the cables from the solenoids. I honestly do not remember exactly how I did it, but I did. I also adjusted the strikers so they lined up better..
Old Jun 11, 2022 | 07:02 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
This happens to me occasionally also. What I have noticed is just like others it can be either side. I noticed that it seems to hang up on the opposite side from which I slam the cover. I figured since you can push down on the side that is hung up and it releases than it must not have seated all the way in the latch. I just lubed the latch mechanism and I now slam the cover from as close to center to get equal pressure on both sides.
Tootie Pang
Mar 18, 2017 12:02 PM
91camarodriver
May 11, 2010 09:08 PM
StealthElephant
Feb 24, 2010 10:20 PM
shapeshifter
Mar 14, 2004 09:30 AM
