Water pumps
Old May 29, 2002 | 09:22 PM
rscamaroman's Avatar
Water pumps
Just wondering what kind of aftermarket water pumps you guys are running? I like the Edelbrocks (especially the polished one), but don't like the price. Are they worth it? I definitely want something with high flow.
Old May 29, 2002 | 10:27 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
running flowkooler on the tpi350 in the formie and i have no complaints so far :-) friend ran the same on his 88gta thats how i ended up wth mine , between here and a few follks i know im not to impressed by the durability of the edelbrocks
so thhere those two or u could check out stewarts pumps as well
laters
Old May 30, 2002 | 10:06 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Stewart Components Water Pumps are used by many Nascar teams.Reasonably priced too. I have them on all three of my GM cars.
http://www.stewartcomponents.com/index.htm
-Rich-
Old May 30, 2002 | 10:44 PM
JPrevost's Avatar
Car: 91 Red Sled
-Rich-
I have yet to hear anybody have any problems with the Stewarts pumps. It seems to me that the only reason you would go with anything else is if you could get em for cheap, else, invest in a Stewarts and they'll take good care of you.
Old May 31, 2002 | 02:01 PM
BenIroc's Avatar
Part number
3,8 Trans Am ,what is the part number of your Flow Kooler pump?
There is one in the Summit catalog with part number:BRA-1774,
Is that the one?
Thanks.
89 Iroc
Old May 31, 2002 | 06:57 PM
I checked Stewart's website and they show 4 different stages of pumps. I know a stage 3 or 4 would be overkill on my car. Stage 1 is similiar to stock. I always want better than stock so I'm thinkin maybe stage 2. What stage are you guys using, if yo are runnin Stewarts?
Old Jun 1, 2002 | 02:38 AM
Ken88GTA's Avatar
Hey rs,
I'm using a Stage 1 on my slightly modded 355. It is much better than stock! Made a big difference. Unless you have had a cooling problem or are planning some serious mods, I would think a Stage 1 would work for you as well. Can't beat it for the money!
Ken
Old Jun 3, 2002 | 07:59 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
I've had the same Flowkooler pump on my Z, 4 years now with no problems. I put one on my Blazer 2 years ago no problems. Just stay away from the bargain shop rebuilt pumps, in fact stay away from bargain shop rebuilt alternators too.
Old Jun 4, 2002 | 10:15 AM
Beefy89's Avatar
Stage 1......
Old Jun 5, 2002 | 11:42 AM
Morley's Avatar
Flowkooler pumps are just stock pumps that have star impellers with the Flowkooler "disk" mounted to the impeller to stop caivitation and push more water. You can get about any pump and pull the back cover, see what diameter disk you need to make and mount it to the impeller. I make the disks for all my water pumps and they work great.
~M~
Old Jun 6, 2002 | 09:01 PM
iroc22's Avatar
Gotta stick with the Stewart water pumps, they are awesome......
Stage 2 works very well.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
