Fan motor shorted
Old Jun 5, 2002 | 11:59 AM
Ride4ME's Avatar
Fan motor shorted
Any tips for replacing the fan motor?
It looks straightforward but you never know till
you get started.
thanx in advance,
R.
Old Jun 6, 2002 | 02:36 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
when i did mine i put the fan in backwards twice just make sure you remember how it goes befor you take it all the way apart. but there should be no problems
Old Jun 11, 2002 | 04:23 PM
Ride4ME's Avatar
My new fan motor's electical bracket doesn't fit the one
coming from my wiring harness? what to do?
Old Jun 11, 2002 | 10:50 PM
89WS-6's Avatar
buy a convertor, or go bitch at the dealership.
Old Jun 12, 2002 | 01:56 AM
Ride4ME's Avatar
what's a converter?
Old Jun 12, 2002 | 12:38 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
the only reason it could be like that is if you have the wrong fan. go to another autoparts store and get one, just take the one you have now back. When i bought one it just bolted on and pluged in.
Old Jun 12, 2002 | 05:22 PM
Ride4ME's Avatar
ok.. I got the right motor and it is in.
But still not working. My old fan motor burned from the inside out.
Is it possible I need to replace something else? My thermostat doesn't seem to work either.
Old Jun 13, 2002 | 01:08 AM
Desert86Roc's Avatar
You will probably need to replace the fan relay also. What do you mean "your thermostat doesnt seem to be working"?
Old Jun 13, 2002 | 03:26 AM
Ride4ME's Avatar
QUOTE]What do you mean "your thermostat doesnt seem to be working"?[/QUOTE]
No temp reading in the dash.
Where is the fan relay?
Old Jun 13, 2002 | 03:58 AM
highhat's Avatar
relay
On mine both fan relays are by the battery on the passenger side
Old Jun 13, 2002 | 08:01 AM
streetrunner's Avatar
i had my fan wired to a manual switch and im guessing it blew the motor. what would be a good replacement fan motor to go with a manuall switch and run all of the time?
i only have one fan.
Old Jun 13, 2002 | 10:38 AM
Boosted GTA's Avatar
Any fan can be wired to run off of a switch, cause that's basically what the fan does. I dont suggest running the fans all the time, that's why they are on a sending unit.
If it did blow because of the wiring to a manual switch, then difinitely find out if it is a ground problem, or just poor wiring. Its not a matter of if the old fan was good enough, but the new wiring could have shorted the fan.
Since you are having a problem with your gauge, check the temp. sending unit to the gauge.
Always remember, KISS (Keep it simple, stupid **not calling you stupid, just how the saying goes**--start with the every basics, and go from there.
1. Check your fuses.
2. Check your wiring to the manual fan switch, make sure you are not over amping the fan.
3. check the sending unit to the temperature gauge. could be bad also, that's why your gauge stopped working.
Hope some of this babble helps.
Mike
Old Jun 13, 2002 | 12:00 PM
ok i clipped the stock wires that went to the fan. then i wired the ground to a ground and clipped it agian to put an inline fuse to it. 15 amp. than i wired it to the accesory thingy in my fuse box. worked realy well and i know that it wasnt the fuse b/c the radio would have gone out too.
Old Jun 13, 2002 | 12:02 PM
im certainly not a electrician so how do i check for those thing and if yopu know how. how do i run a mnual fan switch and have itonly on when the car is on. (not running when car is stopped).
Old Jun 13, 2002 | 01:28 PM
Ride4ME's Avatar
I have a tbi and there are wires everywhere I see, the wires from the electical bracket that plugs into the fan motor coming out of the wiring harness. I still don't have a clue where the fan relay is or what it looks like.
Please keep helping
R.
Old Jun 13, 2002 | 02:06 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
to hook up a manuel switch you must tie into the wire that goes to the fan switch on the passenger side head. then you must run a wire from the wire that goes to the fan switch to the engine compartment and hook up that wire to one side of the switch and hook up the other wire on the switch to a ground.
Old Jun 13, 2002 | 06:00 PM
Ride4ME's Avatar
I don't care about a manual switch...
I just want my friggin fan to work!
I replaced the relay, still no go. What else is there?
Old Jun 15, 2002 | 10:22 AM
86TATpi's Avatar
If your gauge isn't working, check either the temp sending unit's wires or the unit itself. It's located on the drivers side right around the second spark pluge (at least on an 89 tbi v8 and an 86 tpi v8). Sometimes the plastic on the wires that clip onto the sensor breaks or cracks. If the fan isn't going on there is a fan switch on the passenger side of the car directly above the starter that the wire may be loose or the switch may be broken. Both parts are pretty cheap and you can go on partsamerica.com and see what they look like. You can check your fan switch by unplugging the wire going into it and grounding it out. With your car in the on position, that would make your fan kick on. If it doesn't then there is a connection problem in one of the wires somewhere else.
Old Jun 20, 2002 | 05:00 PM
Ride4ME's Avatar
Where exactly is the fan switch?
Old Jun 20, 2002 | 10:28 PM
1987fbd's Avatar
Check this out, https://www.thirdgen.org/newdesign/tech/cool.shtml
Old Jun 21, 2002 | 08:32 AM
the fan switch is located in between the 6th and 8th cylinder spark plugs you will need a 20 mm wrench . you wil ahve to jack up the car or put it on ramps. I just received m fan switch from hypertech it is supposed to lower the temp in which the fan comes on. im putting it in today when i can find my 20mm wrench.
Old Jun 21, 2002 | 05:43 PM
Ride4ME's Avatar
well guys...
I drained my coolant in order to change my thermostat notcing
that I never even had one in there... and I refilled the system with
coolant and guess what??...
MY FAN WAS WORKING!!!!
But guess what else?....
I shut if off and tried to restart it then it DIDN'T WORK AT ALL!!!
What's the deal??
Old Jun 22, 2002 | 12:55 AM
highhat's Avatar
fan relays
find your fan relays just follow the wires from your fans. should be near the battery. make sure the ground from them is clean and tight. the ground wires bolt to the body. My fans were working spuraticaly and weak, sometimes perfectly. turned out the bolt holding the ground to the body was loose and corroded. I cleaned and tightened the connection, fixed my problem hope this helps. later
eightsixseven
Dec 16, 2024 01:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Aug 6, 2015 04:15 AM
