I want to put a LED to see when my fan is running...
Old Jun 11, 2002 | 02:00 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I read the Tech article a while back and the next day I bought the Hayden Fan switch that was listed.
I got that one becuase i wanted to be able to switch between the Hayden and Stock at the flip of a button.
Now I haven't finish installing this just quite yet.
Where do I put a LED to tell when it is on? the book tells me to put it on the a/c clutch but to me that tells me that it will tell me only when the A/c is turning the fan on. What do you think?
Anybody have a diagram or anything?
Hold on while I get some more info...
Old Jun 11, 2002 | 02:21 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Hayden makes a fan turn-on relay (part no. 3652). Available at Pep Boys for about $25.
Features:
Thermal switch mounted in radiator.
Fan turn-on at 185° and off at 170°.
Can be wired to augment factory switch, not replace it.
That's what the article says, but the paperwork I got with the switch says its temps are On 186 and Off at 164, so I go with the paperwork it came with.
https://www.thirdgen.org/newdesign/tech/cool.shtml
How would I wire this up?
I want to have a witch to switch between stock and Hayden (AUTO)
I want a switch to maunally turn the fan on (FAN)
I also want the LED to to display when the fan is on
Also what resistors will I need to install the LED, if any?
Old Jun 12, 2002 | 03:34 PM
Blackened's Avatar
I would wire up the LED to the fan leads directly or you can do it at the relay on the firewall. Just install it in parellel with the fan. Use a 600 ohm resistor or so.
Old Jun 13, 2002 | 10:47 AM
MdFormula350's Avatar
Yeah once the fan is moving the circuit for that fan is complete, therefore current is flowing through and u can just splice into the two fan wires and hook the led up to that. I think that would work, someone tell me if i am wrong.
Old Jun 13, 2002 | 02:10 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
If you have ANY questions about anything that's written in the article, why don't you e-mail the author like the article says? BTW, I wrote the article.
eightsixseven
Dec 16, 2024 01:50 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Aug 6, 2015 04:15 AM
