installed 16" electric fan, can't keep up!
Old Jun 15, 2002 | 11:31 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I just swapped my engine driven fan with a 16" electric.
took it for a nice easy drive and within 5minutes I was over heating.
If I stopped and let it idle it will cool slowly, but any amount of driving and the temp creeps up relentlessly
the fan kicks in at 190, but after a 10min drive it was over 230 already.
I figured a 16" would be plenty!
What can I do to help my fan out!?
Old Jun 16, 2002 | 12:51 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Is the fan mounted directly to the back of the radiator and wired to Pull the air? Is the 16" fan rated to pull at least 1600 CFM of air? 1900 CFM or higher would be ideal. What is the coolant ratio, It should be 70% water 30% coolant or I use 100% water and two bottles of Redline Water Wetter in the summer. Also, replace the water pump and radiator cap and use a 180* thermostat. This is assuming that the radiator is in Excellent condition. You should also, back flush the system using the "Prestone radiator flush kit". After all this is done, you shouldn't have any overheating problems.
Old Jun 16, 2002 | 11:24 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
the fan is rated to pull 1530 cfms and 1200cfm through a rad.
I need 1600 cfm through the rad?
Comparing to my belt driven fan, it sucks, before the swap the temp would only get up to 185 on the cool day we had yesterday.
grr, all that work!
Old Jun 16, 2002 | 12:14 PM
Lounge Lizard 6's Avatar
Do you still have the airdam below the radiator installed? If you don't, it can overheat while on the move.
Old Jun 16, 2002 | 04:15 PM
CrazyRob75's Avatar
check out Vintage air. They have a 16" fan that pulls 2700 CFM. Our shop sells 'em for around $225 Canadian.
Old Jun 16, 2002 | 08:55 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i went to the dual fan setup. i don't the air flow but they are helping my car run cooler.
Old Jun 17, 2002 | 08:38 AM
craiger's Avatar
You might want to put some redline water wetter in the coolant too! It will help drop your temps down once you get into the 220 range.
Old Jun 17, 2002 | 08:57 AM
scauffiel's Avatar
Make sure the blades are in properly to pull the air as someone mentioned earlier. When I received mine from Summit I had the same issues, I did the ole "feel the flow" test (putting my hand behind and in front of the fan) and there was more flow coming out from the front of the radiator than from behind the fan. Add to that actually driving around and I bet you have zero flow. Pull a c clip flip the blades around reinstall c clip and voila, much better.
S.
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Cameeeero
Aug 20, 2015 03:06 AM
86IROC112
Aug 17, 2015 02:00 PM
Firebird sweden
Aug 16, 2015 05:02 PM
