What if gauge reads 240 but....
Old Jun 27, 2002 | 01:57 PM
CAMARO82's Avatar
what if your gauge reads 240 but it doesn'r boil over?????? is the gauge bad or what?????
Old Jun 27, 2002 | 02:00 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
not if your rad cap is good and you have no leaks...system is pressurized...makes the boiling point higher.
Old Jun 27, 2002 | 03:24 PM
Desert86Roc's Avatar
Our gauges (and or sending units) are notorious for being way off. Verify your real coolant temp.
One way is to borrow a IR thermometer and shoot the temp at different places. Like the sensor in the head and at the thermostat housing and see what the difference between that and your gauge reading.
Old Jul 1, 2002 | 09:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
or, you could be cheap and lazy like me, and just replace the temp gauge sending unit.... about 95% of the time, that's what makes the gauge read wrong
Old Jul 1, 2002 | 10:14 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, coolent boils at around 212*. Every pound on your pressure cap is worth around 3*. So a 16# rad. cap = 48* + 212* = 260*. So when your gauge hits 260 shut it off.
Auggie
Old Jul 2, 2002 | 01:38 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Actyally water boils at 212, an Ethylene glycol/water mix will have a higher boiling point. How high depends on your mixture.
Old Jul 2, 2002 | 10:31 PM
Auggie's Avatar
Well, thats good info. I have a 50/50 mix. What will my coolent boil at without a rad. cap.
Auggie
Old Jul 2, 2002 | 10:50 PM
CAMARO82's Avatar
But when should I decide to turn it off at what temp.? Actually mine runs cooler on streets rather than highways If that sounds weird or not?
Old Jul 3, 2002 | 11:35 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Mine has survived 260 degrees without boiling, with a 16 pound cap and 50/50 Water/Antifreeze. I know the temp was real, as it was a mechanical gauge on the thermostat housing.
Just lucky I guess. Pretty good test for leaks, though!
The factory gauge is very inaccurate.
I can compare readings with the mechanical and sometimes they match, sometimes they're 40 degrees different!
A new sender may help, but it may not.
A bad ground can also give an electrical gauge flaky readings.
I'd try to avoid letting it get over 230, but 240-245 shouldn't kill it.
above that is head-gasket danger zone.
-Rich-
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
355sbcTPI
Aug 19, 2015 04:38 PM
