water pump going bad?
Old Jun 30, 2002 | 02:26 PM
trd51398's Avatar
Hey everyone,
was out all day long yesterday driving in about 85 degree heat and it never got up over 220. Well, I woke up this morning and there is a antifreeze all over the ground. It looked like my lower radiator hose had a hole init, so I replaced it , fill everything back up ,, start the car and it still leaks.
Could the water pump be going bad and leaking somewhere? Anything will be very helpful. thanks
Its an 88 Iroc with the 5.7 350
Old Jun 30, 2002 | 09:36 PM
dale davidson's Avatar
u couldnt see exactly where it was leeking from?(thats not a joke)
Old Jul 1, 2002 | 06:12 AM
trd51398's Avatar
no I couldn't see where it was coming from. The antifreeze was leaking down the back of the lower radiator hose. I followed it up to the water pump and thought that the hose came loose and when I took the hose off it did have a little tear in it. so I replaced it, and then got the car going again and it still leaked.
thats why I am thinking that the water pump could be going bad.
Old Jul 1, 2002 | 03:46 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, on the bottom of the water pump housing there is a weep hole drilled between the front and back bearings that hold the impeller shaft. If the seal goes bad coolent will leak out of this weep hole and believe me that hole is hard to see. Good Luck!
Auggie
Old Jul 3, 2002 | 09:05 AM
i agree, a freind of mine had the same leek on his cadillack
Old Jul 3, 2002 | 10:20 AM
trd51398's Avatar
Thanks for your help . I ordered a new water pump, I figured if this went, then its on its way out.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
Newguy91rs
Aug 7, 2015 09:51 PM
