Wiring relays for both fans together...
Old Jul 5, 2002 | 04:13 PM
KlayBuRn's Avatar
I'm kind of stupid, so any pictures of this would help me out a lot...
Heres what i want to do...
I want to take the relays and make it so when the first fan kicks on from the ECM, i want the 2nd fan to get the same juice and turn on also...
Can anyone show me pictures of the wiring so i can get this done?
I know nothing of relays...
92 Z28 350 TPI G92 Bone Stock...
Old Jul 5, 2002 | 09:14 PM
breathment's Avatar
that is actualy a very good idea. I'll play around tomorrow and see what i can come up with and take a few picture, if someone else doesn't answer this first..
Old Jul 6, 2002 | 12:36 AM
KlayBuRn's Avatar
Ok cool ! :hail:
Old Jul 6, 2002 | 12:41 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
This might help you out some...
https://www.thirdgen.org/techbb2/sho...hreadid=115154
Instead of a toggle switch though as in the drawing, the ECM (as it would be OEM) is controlling the primary fan relay, if you tie the green/white wire of the primary to the 2ndary, they will both kick on as called for by the ECM or A/C. ECM or toggle, as long as the relay grounds are tied together, they will both kick on at the same time.
Old Jul 6, 2002 | 12:06 PM
Bad406Z's Avatar
Car: 85 Camaro
Engine: NA
Transmission: NA
Axle/Gears: NA
You can also join the + and - wires of both fans together and that will work as well. Mine have been like this for years with no problem at all. It only took about 10 minutes. And if you want to hook up a manual switch just find the wire of the temp sending unit and tap a wire into that has a togglw switch in the circut. Conect it to a ground and you have a fan switch. All the temp sending unit does is ground out the circut to turn on the fans onec it reaches the temp of your unit, now you can do that manualy with you switch.
Old Jul 6, 2002 | 04:03 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Thanks Deadbird, I gutted my A/C so my secondary fan dident work. I followed your pic and now they both work!! But on my 92 the primary fan gound was green with a white trace and my secondary ground was gray with white trace. Not both Geen. Just a note.
Old Jul 6, 2002 | 04:47 PM
deadbird's Avatar
Engine: TPI 305/ v6
Good to hear Randy.
I know the 2ndary fan isn't always green/white but, over the years it changes colors so I just kind of generalized the drawing (using the quick cut & paste method.. to lazy to actually draw new stuff ).
On my 87, the 2nd fan ground wire was black from the sensor/switch and then green/white after the harness plug. I've seen another all black & the 88 harness going into my buds truck is grey all the way to the relay as well. At least you were able to get your fans working though
John Millican actually posted over on the electronic forum, what I failed to find in an 91 service manual to copy for others, and excellent image of how the later years dual fan setup is wired as shown below..
Attached Thumbnails Wiring relays for both fans together...-92-7730v8tpi-4.gif
Old Jul 7, 2002 | 06:57 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
You also really should add a time delay to the turning on of the secondary fan. I built this time delay circut and it works excellent. See this post for an explaination;
https://www.thirdgen.org/techbb2/sho...threadid=24311
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
