Please help, oil cooler problem
Old Jul 31, 2002 | 09:28 PM
gtabadboy's Avatar
I got rid of my ac and heater core in the car. I have an oil cooler in my engine. One of the hoses went from the cooler to the heater core in the back of the motor. How can I run this cooler now? I am clueless as to how it goes or if it will work right. Thanks
Old Jul 31, 2002 | 10:19 PM
breathment's Avatar
run it from the cooler straight to the radiator..
Old Jul 31, 2002 | 10:26 PM
gtabadboy's Avatar
theres 2 hoses from the coooler. I think one goes to the radiator where does the other go?
Old Jul 31, 2002 | 11:04 PM
breathment's Avatar
this should help, i hope
Old Aug 1, 2002 | 08:25 AM
gtabadboy's Avatar
the only problem is that I removed my heater core in the rear of the car at the firewall (those two pipes in your pic). Therefore I cant run the hoses there. Is it worth it to keep the cooler. Is there any other way?
Old Aug 1, 2002 | 10:44 AM
92RSB4C's Avatar
What is #4???? I don't have it on my car. Maybe that's why its over heating??
Old Aug 1, 2002 | 12:07 PM
gtabadboy's Avatar
Im not sure but I know that #4 has antifreeze flowing to it. Maybe it opens and closes to let the fluid flow. I would assume that if you dont have one then the fluid flows freely and this could not be the cause of overheating.
Old Aug 1, 2002 | 02:09 PM
breathment's Avatar
alright, you need to run the hose coming out of the throttle body #3 straight to he IN of the oil cooler, and bypass all that other stuff.. and keep 7 coming out of it. that SHOULD do the trick, let me know
92RSB4C - that is the heater control valve which opens and closes alowing coolant to flow into the heater core, or it bypasses the heater core and lets the coolant run either to the oil cooler or back to the radiator
Old Aug 1, 2002 | 09:08 PM
gtabadboy's Avatar
I do not have a TPI in my car. I converted to the engine in my sig.
Old Aug 1, 2002 | 10:00 PM
breathment's Avatar
then instead of it coming out of the T.B. then i think it comes out from the front of the block...
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
