Car turns off fan won't , why?
Old Jul 31, 2002 | 11:40 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
I've got a 91 Z28 w/350/auto. My question is my fan runs all the time. It won't shut off when I shut the car off. I now have to disconnect the battery when I park it. Is it possible that even though it's controled by the ecm, that there is a relay downstream from that? If there is could it be stuck shut (contacted). Where would the relay be located at? I looked it up in the Haynes manual, my car is a G92 car, I assume that means heavy duty cooling system right? Not much info in the book other than a wiring diagram showing a always "hot" 12v line w/ a fuseable link, and then a heavy duty relay, followed by, you guessed it.....the promary ccoling fan. PLEASE HELP SAVE ME!!!! I HATE POPPING MY HOOD ALL THE TIME! It makes me look like I have a POS when I go to a store or resturaunt and I have to disconnect the battery first.
Old Aug 1, 2002 | 01:17 AM
breathment's Avatar
im not sure about Camaros, but on my GTA, the two fan relays are located on the passenger side, one next to the radiator, one on the fender..
the secondary fan isn't controlled by the ECM. its controlled by a fan switch. so unless both fans are set to come on together..
But i bet it has something to do with the wiring.. Im working on a tech article that will have all that stuff in it..
Old Aug 1, 2002 | 06:40 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Thanx, let me know when your done with that article. I'd definitely like to check it out. Any one else help me at all? Any other possibilities?
Old Aug 1, 2002 | 10:34 AM
92RSB4C's Avatar
The relays on later camaros are next to the brake booster on the firewall. I think the primary cooling fan is the farthest one on the left (passenger side). The one in the middle is the fuel pump relay, and the one on the right (drivers side) is the secondary cooling fan.
Old Aug 1, 2002 | 11:05 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
How do you test this realy. Is there something you do to jumper it or short it to make it open and shut?
Old Aug 1, 2002 | 11:27 AM
MdFormula350's Avatar
sounds like someone may have grounded the fan!!
so basically they have the always hot +12v that goes to the fan and the heavy duty black (ground) connected to complete the circuit thus the fan is on alllll the time.
i had a similar problem with my car the passengers side fan would come on and stay on when i would just turn the car on, and that turned out the the fan switch got burnt up somehow and grounded itself.
Old Aug 1, 2002 | 11:47 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
I already checked for that... the black/pink stripe wire runs all the back along the pass. side into the car (looks like it...) And there's the factory groung lug on the fender. That's it
Old Aug 1, 2002 | 12:03 PM
the relay must of been totally bypasses or something. because the fan would not just run all the the time unless it was getting +12 all the time.
Old Aug 1, 2002 | 02:11 PM
breathment's Avatar
here is the wiring for the fans
Old Aug 1, 2002 | 02:22 PM
breathment's Avatar
here is the pinout for the relay CONNECTOR
make sure there ISN"T volatage at E with the ignition OFF
Old Aug 1, 2002 | 07:50 PM
very nice pics, they should help him alot.
i even saved those pics for future reference.
Old Aug 1, 2002 | 09:08 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
I want to thank all who replied, especially breathment, and 92RSB4C. I did'nt know where the relay was for starters and the diagrams were of serious help. Reconnected the battery and the fan started as usual. Then I tapped the relay and guess what? After about 3-4 taps the fan stopped running. Diagnosis: stuck relay. It's intermitent though, but that did'nt stop me from replacing it. 9.99 at auto zone. Sorenson MR44. BIG THANX GUYS!!!!!!
Old Aug 1, 2002 | 11:06 PM
cool glad to hear that you fixed the problem!! :lala:
Steven 86IROC-Z
May 24, 2026 04:52 AM
RazorN8
Jan 7, 2022 11:44 AM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
