Fan wont kick on
Old Aug 13, 2002 | 06:30 PM
88bluebird's Avatar
Fan wont kick on
I put in a new temp sensor, relay, fan motor, even a new rad cap thinkin maybe theres a pressure switch.... nothin. I put a manual switch to the relay, but im tired of checkin the temp. does anyone have any ideas???
Old Aug 13, 2002 | 09:55 PM
breathment's Avatar
so teh fans do work with the Manual fan switch? and which temp sensor did u replace, like the location of it
Old Aug 13, 2002 | 10:29 PM
88txiroc's Avatar
Check the 6 pin connector on the pass. side of the radiator. My fans did the same thing and my ground was bad at the connector. It is the weather-proof one. The ground on my car goes from the radiator support above the headlight to the connector. I dont know if your bird is the same as a Camaro when it comes to wiring, but it is worth a shot.
Old Aug 14, 2002 | 06:15 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
On the TBI models the ECM is not used for fan control, only a switch. "T" is correct, check to see which sensor you replaced. If the one you replaced has 2 wires it is the wrong one. That is the CTS that feeds the ECM. The fan switch is located on the pass side of the block between cyls 6-8. It has a single black wire going to it. Do you have AC? If so you can turn on AC and fan should run. It may be as simple as the wire going to the fan switch came off or is burnt.
Old Aug 16, 2002 | 02:59 AM
88bluebird's Avatar
I changed the sensor at the front of the motor. The parts store told me thats the only temp sensor on the car. Danno, is that switch above the starter??? When I was changing the starter this past weekend (2nd time in 2 years) I saw a single wire coming out of the block. Is it just called a fan switch???
Old Aug 16, 2002 | 05:36 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You changed the coolant temp sensor unfortunately. The gizmo you saw is either the anti-knock sensor or the fan switch. The fan switch is a small brass unit with a single wire. The knock sensor is also a single wire unit but it is larger. Remember the fan switch sits in the water jacket so you will have to drain coolant to change it. Before you change it, once you are sure you have the correct one turn on key and simply touch the wire to a good ground. The fan should come on. If it doesn't, don't waste time changing it as it is not the problem.
Old Aug 21, 2002 | 10:17 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey DANO i just converted ti carb from tbi and ripped out the comp and the car runs beautifully except the fan doesn't work and i have no idea why.the sensor is new and it worked be4 the swap.i had to cut the black with a pinkstripe wire from the pan and i hooked a switch to it then a wire off the switch to the battery just to get the engine all adjusted. now how do i make it come on by itself and wut temp should it come on by itself? thanks oh also does the interior fuse control the fan cause i had it out and now i;m wondering? thanks
Old Aug 29, 2002 | 05:16 AM
88bluebird's Avatar
Well Danno, I had a hell of a time gettin to it, dipstick was in the way for a ratchet. Largest wrench I had was a 3/4 and the damn thing was a 13/16. After callin a couple friends, I got a wrench. Drained the rad, took the switch of expecting a little coolant, got a shower, but finaly got the SOB to work. Thanks for your help.
Old Aug 29, 2002 | 06:55 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
OK, based on your screen-name I am assuming it's an 89. 89 models with a 305 TBI did not use ECM for fan control so nothing should have changed. The fan sensor is on the passenger side of the block and has a single wire. It is a small brass fitting. That controls the fan relay. The single wire plugs into the fitting. If you take the wire off simply touch it to a good ground with the key on(engine can be off) and the fan should turn on. The fan circuit should NOT be on the same line as the interior lighting unless it was changed by someone. Stock fan turn on is around 230 degrees, you can get a lower switch from NAPA that will kick on around 215 or so, it's up to you. By the way, does the Jughandle Inn still have the best hot wings? Spent a lot of time there when I was with RCA.
Old Sep 11, 2002 | 08:02 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
SAME PROBLEM WITH MINE
Alright my 1992 305TBI is doing the same thing. THe fan comes on only when i turn the AC on. IT was working just fine, it just did this today for the first time. I even tried using the Digonstic mode(paper clip in the ternminal) to see if the fan came on it didnt. So im trying to change the part you all listed between the 8 and 6 cy. Only the dang thing wont come out. I got the right tools cant get it loose so im working on that part. Also Autozone sold me a part that isnt the right one. They are telling me that the thing im changing a coolant temp sensor, so thats what they gave meonly its not the right connection peice so i know its not it. I have the part number for the thing i do need though so im gonna go back with it and get the right part hopefully. Any more information you could all pass along id be greatly apprciated. If the Dipstick wasnt in the way no problem but it is, any ideas thanks guys.
Old Sep 12, 2002 | 05:27 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
According to my diagrams only tuned port models will activate the fan with the ALDL connector jumped. Before you change it just ground the wire to a good frame ground with the key on, engine off. If the fan comes on everything else is OK. Don't overlook a funky fan relay, GM had ton's of problems with them. many times part guy's confuse the coolant temp sensor with a fan switch. CTS has 2 wires, fan switch 1. It is best to work on it from the bottom if you can.
Old Sep 12, 2002 | 04:59 PM
Firebird90V6's Avatar
PART number or actual name of part
Alright im having trouble getting the right part to fix this problem Autozone sold me a Temp sensor and i know its not the right part. They tell me that the Fan switch is on on my fan not between the 6 and 8 Cyl. Im going to go to a different Autozone and check into this, but can anyone help me with the for sure part name and possible a part number? thaks guys.
Old Sep 13, 2002 | 05:22 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: PART number or actual name of part
Does your handle indicate your drive? If so none of this applies.
Old Sep 13, 2002 | 06:49 AM
not my ride
No my handle doent indicate my ride. Its a 92 305 TBI, i have that one, a 85 TPI trans am and then the 90V6. ITs the TBI that has the fan problem. Im got the righ part from a smart guy at autozone, he actually knew what i was talking about.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
tattmann
Sep 27, 2015 05:20 PM
