this was steaming, my car overheated, what can i do?
Old Aug 14, 2002 | 05:12 PM
igotslicksNchix's Avatar
hey guys in the past 2 days i've been having an overheating problem. today i actually had a puddle on the ground and this thingy was steaming......not sure what it is i've only learned to fix cars that are ancient w/ no a/c and carbs on top. what is it and can it be bypassed? the thing circled in red is what had steam coming from it
Attached Thumbnails this was steaming, my car overheated, what can i do?-overheat.jpg
Old Aug 15, 2002 | 02:26 PM
GoldenSwordZ28's Avatar
I don't have a TPI car with all the advanced Electronics or Various New Tech stuff on it, but to me that looks like part of the emissions system, but lemme go look at some other engines real quick for a better look. I'm sure someone that knows the answer to this will post.... but if not I'll try and find out.
Adam
Old Aug 15, 2002 | 04:16 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Diverter valves for the AIR pump.
Old Aug 15, 2002 | 05:35 PM
and in plain english it would be????
Old Aug 15, 2002 | 10:28 PM
deadbird's Avatar
Engine: TPI 305/ v6
Plain english...... Diverter valves for the AIR pump
They are the valves that control (ECM related) where the AIR (emissions crap) pump puts the air.. one diverts air to the manifolds and the other to the cat converter (temp depending) to aide in emissions.
Unrelated to your cooling system.
Old Aug 15, 2002 | 11:40 PM
thanks bro, wonder why it would do that?
Old Aug 16, 2002 | 02:47 AM
uk89camaro's Avatar
are you sure the steam wasn't coming from the heater vacuum switch. Thats the thingy at the 5 o'clock position on your red circle. has either 2 or 3 hoses connected to it. The connectors become brittle after a while and crack at the body. has the valve cover shown any signs of water damage to the paint?
Old Aug 16, 2002 | 08:39 AM
well took a look at it. valve covers look like there may be a tiny leak from it, (possibly) BUT i looked at it, there are two hoses connected to it, and a third opening that looks like a hose should go to it on the side of the thing. you can see inside of the heater vacuum switch...is this opening supposed to be there?
Old Aug 16, 2002 | 10:00 AM
uk89camaro's Avatar
You have TPI, mine's TBI, but I would suggest that if you have an open end off the valve, something is not right! These valaves came with eitrher 2 or 3 outlets, do you have the right one for your car?
Here's a picture of mine.
Attached Thumbnails this was steaming, my car overheated, what can i do?-thirdgen-heater-valve.jpg
Old Aug 16, 2002 | 10:29 AM
i dunno, there is three outlets, i'm going to go look for dangling hoses or something. while i'm at it i plan on hooking up a manual fan switch, any tips on that?
Old Aug 16, 2002 | 10:37 AM
ya, and i lost coolant it appears as well!!!! i might buy a brass plug.....
Old Aug 31, 2002 | 09:28 AM
uk89camaro's Avatar
fan switch
I followed the tech article on this one. Really easy, and no worries about putting additional load on wires and switches. Haven't got the link, but it;s the one that talks about grounding the green/white wire from the realy.
Old Aug 31, 2002 | 08:44 PM
hey thanks for the info, i changed the water pump and no more heat related problems for a week or so now, as for the fan switch it seems to be working correctly, so it's a "if it ain't broke don't fix it" situation. but if it does break, now i know how to fix it thanks guys
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
