What happens if you plug off the outlet line off the heater but leave inlet connected
Old Aug 15, 2002 | 01:23 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I bought a griffin 31X19 aluminum radiator for the camaro to fix the overheating problem, which worked, but I just plugged the extra line that was supposed to go into the radiator, even though there is still a line going into the heater that is connected. Will the heater blow up or something if I leave it like this? I was thinking maybe I should plug it but.......................she would kill me if I deleted the heater on her car.
Old Aug 15, 2002 | 02:28 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Hahaha, you have the exact opposite problem as me dude.
My guess it seeing as how you pluged the "out" and left the in connected, the coolant has knowhere to go, so it could go boom. But I think coolant goes through the heater core only if the heat is on, so you might be safe there. why dont you bypass the heater core until winter? she can still use A/C.
I am having a problem with the heater core out, it is still getting coolant in the heater core so my passenger side floor has a nice puddle of coolant
Old Aug 15, 2002 | 11:12 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Just connect that heater line to the top of the water pump using a threaded pipe adapter.
Old Aug 16, 2002 | 09:26 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Neither of my heater lines go into the radiator.
One goes into the intake and one goes into the water pump.
Old Aug 16, 2002 | 01:40 PM
82camaro's Avatar
Car: 82 camaro SC
Doubtful the core will pop, but who knows. Set it up like the post before me. That's how mine is, and how is should be hooked up if you don't have a radiator return.
Old Aug 16, 2002 | 02:31 PM
Car: Junk
hey guys the water pump on her camaro doesn't have any NPT outlets. I deleted the heater. She's gonna be pissed!
Old Aug 16, 2002 | 02:59 PM
99Hawk120's Avatar
If you have a serpentine system, you're correct, the factory water pump does not have any NPT outlets.
However, Stewart makes serpentine water pumps, and their's DO have the NPT outlet. I know, I have one on my car (Stage II Aluminum) since I swapped over to serpentine. The original picture is old and shows my car with v-belts, but the heater hoses are STILL routed EXACTLY the same way.
The Stewart Stage I pump has the outlet as well since that's what my friend has in his '92 RS.
If you want a heater that works, just get a stewart pump. You probably need a new pump anyway, right?
Old Aug 16, 2002 | 09:30 PM
GKK's Avatar
GKK
On a Serpentine system the Stock water pump Does have an NPT water outlet. The Stewart Stage 1 water pumps use Stock Factory water pump castings to build thier water pumps. I took the stock water outlet plug off of the stock pump to use in the Stewart Pump on my Serpentine belt setup.
Old Aug 16, 2002 | 09:53 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mine didnt. i had the stock pump it had no NPT outlet, the stage one does. whos says they dont use older stock housings with different internals
Old Aug 16, 2002 | 10:47 PM
GKK's Avatar
GKK
Yeah, I guess the factory must have used different water pump housings and just assembled the internals for the serpentine or v-belt setup. I'm just wondering, since Stewart uses the stock housings to make their Stage 1 pumps, Do some of their pumps come without the NPT outlet and some with it?
Old Aug 19, 2002 | 08:33 AM
99Hawk120's Avatar
Possibly. Maybe some cars with serpentine used the water outlet there, I don't know. They aren't using old V-belt pumps because those have extra bosses cast into them for bolting brackets to them.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
camaroken83
Aug 10, 2015 11:35 AM
