coolant doesnt shoot out when cap pulled off
Old Aug 27, 2002 | 08:47 PM
primer84z's Avatar
shouldnt coolant come out when the engine is at operating temps and you pull off the radiator cap? i did this the other day right after i had been driving around for a while. the temp guage read to be a little over the quarter mark. i shut the car off and popped the hood. i pulled the cap off real quick expecting to get coolant everywhere and nothing happend. is this normal? i was trying to check the coolant level becuase that day it had come up too almost to the 220 mark but not quite and it has never done this before.
Old Aug 27, 2002 | 10:16 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i pulled my cap one day when it was at 220, big mistake, coolant in my face...
Old Aug 28, 2002 | 08:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your temp is OK but maybe your gauge reads high.
However, coolant with the correct amount of antifreeze boils at well over 212°; so if your cooling system doesn't hold pressure, then it's pretty normal for it .... not to have pressure.
Old Aug 28, 2002 | 10:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There should be pressure below the boiling point though.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bstrang6
Sep 8, 2015 04:29 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
