Would a Oil Cooler be allright to put on a daily driver/occasional racing Camaro
Old Sep 4, 2002 | 06:55 PM
iroc_cragg's Avatar
Hey
The car is a daily driver, I sometimes go to the track to do some 1/4 mile runs. Would it be alright to put a oil cooler on the car, or would the oil be to cool.
The engine runs quite hot while inner city driving but runs cooler on the highway. I use 10W30 oil.
Old Sep 4, 2002 | 08:32 PM
JOHN/88IROCZ's Avatar
It would be a good install. Your oil will be cooler and the viscosity wouldn't break down as fast. It would probably help keep the engine temps down during innercity also. Go for it is not going to hurt just help.Hope this is helpful.
Old Sep 6, 2002 | 02:13 AM
wavslav's Avatar
Re: Would a Oil Cooler be allright to put on a daily driver/occasional racing Camaro
Keep in mind that even when your water temp is 160 or 180*
the oil temp could easily be 240* or 250* or hotter.
Install an oil temp guage and you'll flip out on whats going on in your motor.
I just got my oil cooler , and waiting to install it.
E
QUOTE]Originally posted by iroc_cragg
Hey
[/QUOTE]
Old Sep 7, 2002 | 12:17 AM
iroc_cragg's Avatar
Thanks guys
Does anyone out there have a oil cooler on there car. How does it run, does it run cooler or anything.
Old Sep 10, 2002 | 04:31 AM
shotgun's Avatar
Car: 89rs
All 350 iroc/z28's came with oil coolers stock, obviously they thought it was important enough to mandate it. I'm sure a bigger aftermarket one will cool a lot better but if your using a synthetic like mobil1 it actually protects better the hotter it gets. (obviously there is a point like 700degrees plus where it starts to break down, but I know its way up there before it actually starts to degrade in performance rather than increase.) Personally though, if it keeps the car cooler and the oil happy whatever.
Hope I don't sound like an *** everytime I post something everyone usually stops talking in the post and I'm tired so im not really gonna read what I'm thinking.
Old Sep 10, 2002 | 08:45 AM
89ProchargedROC's Avatar
All 350 IROC/Z28 didn't come with oil coolers......
but if yours didn't come with one...it is a good mod to do
Old Sep 10, 2002 | 04:19 PM
shotgun's Avatar
Car: 89rs
ok I dug up some info on the history board...
seems if your car came with the L98 it should come with the RPO..
B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
which consists of an oil cooler and some other stuff. People in the board are saying that from 87-92 (or 89-92, I forgot already) Some people didn't get oil coolers. Weird configurations were known to happen like that because of part availability, ie some irocs with 350s came with 115 speedos from the factory. Also some LB9s came with oil coolers stock they are saying. I thought it was only L98s so who knows.
Old Sep 10, 2002 | 08:26 PM
In 1989........You could order an IROC-Z with a 350 motor and as an option you could order the performance option which gave you twin cats, 3.27 gear instead of 2.77, and an oil cooler
Old Sep 10, 2002 | 11:12 PM
shotgun's Avatar
Car: 89rs
89 was the changover year for the 10bolt and it never had 2.77 or 3.27 gears (2.73 and 3.23) anyway there was stock irocs pre 89 with 2.77 gears and a factory oil cooler. I'm just saying there were weird configurations
Old Sep 11, 2002 | 05:31 PM
KlayBuRn's Avatar
My 92 Z28 5.7L TPI with the G92 came with oil cooler(oil cooler was part of G92 with AC package)...
I imagine it helps, but nothing i can see as i dont know and dont have a oil temp gauge...
Old Sep 14, 2002 | 08:14 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
i have an 89 iroc with a 350 tpi and i didnt come with the KC4 oil cooler or the N10 dual cats from the factory. it does have the 2.77 9 bolt rear end with disc brakes from the factory. i have put on a factory oil cooler and the dual cats, but they werent a factory item on my car. dont know why, it has just about every other option from the factory.
Old Sep 15, 2002 | 01:34 PM
MdFormula350's Avatar
oil cooling is a good thing...
some weird configurations indeed from gm..
i thought for the most part most/all 350 tpi cars came with an oil cooler.. i believe all three of my 350 tpi's car came with oil coolers.
InfinityShade
Aug 22, 2015 08:00 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Amillionoh7
Aug 7, 2015 01:24 PM
