Temp gauge sticks past the red
Old Sep 16, 2002 | 06:47 PM
tpirocz's Avatar
Car: 89 IROC-Z & 94 Z71
Engine: both 5.7
Transmission: both autos
My temp qauge sits way up past hot. Sometimes it works, but usualy not. When it does the car runs under 200. How could i fix this. what could it be getting aought on? thanks
Old Sep 17, 2002 | 05:45 PM
breathment's Avatar
replace the temp SENDING unit
Old Sep 17, 2002 | 09:58 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If the gauge itself is sticking during the start-up test sweep, the sending wouldn't be the problem. Sometimes the gauge just gets some slop in it over time and starts popping over the lip of the gauge face and sticks.
Old Sep 18, 2002 | 05:14 PM
87IROC350HO's Avatar
My gauge was sticking also. I took gauge out, cleaned it and haven't had the problem since. This is a good time to clean all of the guages and replace bulbs
Stan
Old Sep 18, 2002 | 09:39 PM
rezinn's Avatar
deadbird is correct, you need to remove the cover and bend/cut the side of the guage so the needle cannot stick.
Old Sep 19, 2002 | 06:44 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The guage has no real bearing for the pointer shaft. After age it will start to get sticky and as everyone said generally hangs up during the start test phase. DB's method works however you can take it out and drop some very light oil down the shaft while GENTLY working the pointer back and forth. Leave it sit for a few days face up then try installing it. I have done a few this way and have had good results. Another way I have fixed it is by drilling a tiny hole in the face at the stop area or max reading area of face and I painted a resistor lead black and inserted it into the hole essentially making a stop pin. Leave the resistor lead out the back far enough to put a few drops of good quality epoxy to hold it in place. Don't try to solder it, you'll destroy the painted surface of the guage. It makes a pretty nice repair if it's done carefully.
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
