ac and heater problems
Old Sep 29, 2002 | 09:04 PM
jcjohnston78's Avatar
i was wondering if my blower is bad as well as the compressor.
i have 1992 camaro RS 305TBI
i still have the orginal compressor and it was serviced this year and my mechanic said its not gonna make another summer. this is whats happening; during the summer cold air trickles out of the vents and in the winter the heat trickles out and is not so hot its just kinda warm
if you need any more info on my ride just look below
thanx
Old Oct 5, 2002 | 08:16 PM
breathment's Avatar
you probably need a new blower.. just make sure that u have it on MAX a\c.. and check to see if it maybe blows out more air on the fan speed that is before HIGH. because there is a seperate relay\switch for when u turn the fan speed to HIGH.. so maybe its just that is scewing up...
Old Oct 8, 2002 | 04:12 AM
Andy Bush's Avatar
Hi You might also check the vacuum line from the engine is connected. The heater system uses vacuum powered valves to open the flaps which control the heat flow.
Old Oct 8, 2002 | 09:25 AM
MdFormula350's Avatar
yeah check sounds like the blower motor, just the connections arouns it (maybe a loose) or maybe its in a relay or some kinda eletronic part went bad..
maybe run a search on here and see if someone had close to the same problem..
Old Oct 8, 2002 | 02:40 PM
i was messing around under the hood yesterday, and noticed that most of my vaccum hose were rotten...i even found that some dumba$$ had disconnected the egr valve....also found the hose that deals with the ac was disconnected and ball bearing was shoved inside the hose.....
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
