Rad swap
Old Nov 4, 2002 | 01:42 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Rad swap
The rad in my car is leaking and I need to replace it. I was wondering if there is another "stock" rad that I could swap in instead that will improve my car's cooling ability.
I swapped in a mild performance 350 in for the 305 and now it runs HOT. What is a good swap w/o breaking the bank?
Old Nov 4, 2002 | 02:32 PM
92camaro's Avatar
How much are you wanting to spend? I just put a Griffin rad in a 92 camaro. He purchase the univeral 31x19 and the fit was fine. We had to do a little work to the stock piece that goes across the rad but we got everything to work. The car runs around 160-170 and it take forever to heat up. The rad. was 189.00 from Summit. You might want to look into something like that if you can afford it.
Old Nov 4, 2002 | 02:43 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Or if you wanting to go cheap, Autozone, maybe some of the others, have 3-row replacement radiators for around a $100. The only benifit I see with these though, besides the extra row in the radiator, is the sides are not plastic like the stock one are.
Old Nov 5, 2002 | 06:19 PM
MdFormula350's Avatar
i just bought the direct stock replacement from Advane Auto Parts from Modine for 118 bucks...
sounds like you might need to upgrade to a dual setup to keep cool in traffic..
Old Nov 10, 2002 | 08:37 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I got an all aluminum (no plastic tanks) radiator for my '85 Z from Performance Radiator for around $190. I never had another radiator problem after that where as every 3rdgen with the factory radiator that I've owned (4 of them) has leaked eventually.
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
